| Offset for coating thickness? [message #19916] Sun, 31 October 2010 21:14 UTC |
I am using Solidworks to design parts for RP.
Recently I discovered Metalise It, which deposits a metal layer onto RP parts to give better strength and surface finish.
The process deposits a 100-200 micrometer thick layer onto all surfaces. How can I remove a 200 micrometer skin from all surfaces to accommodate the coating thickness?
QX
| Re: Offset for coating thickness? [message #19917 is a reply to message #19916 ] Sun, 31 October 2010 21:41 UTC |
You could use face->move (select offset, not translate or rotate).
