| Re: Liar Pendant [message #19618 is a reply to message #19581 ] Mon, 25 October 2010 16:15 UTC |
If a liar admits to being a liar, wouldn't that make him honest? (remembers an old star trek episode where Spock defeated super genius computers with contradicting logic)
| Re: Liar Pendant [message #19632 is a reply to message #19581 ] Mon, 25 October 2010 20:00 UTC |
I'd wear it to give fair warning. It might be less noticeable if you gave it some 3D twist so that it only read liar when looked at in one direction.
| Re: Liar Pendant [message #19633 is a reply to message #19581 ] Mon, 25 October 2010 20:35 UTC |
huh? when you wear it it's vertical.. so you cant tell it spells liar.. only when you look at it when its positioned horizontally ..
http://www.3Dizingof.com
| Re: Liar Pendant [message #19635 is a reply to message #19633 ] Mon, 25 October 2010 20:50 UTC |
It would be even cooler if you made it to read "Liar" from one side, but "Love" or something opposite from the other side! Kind of an ambiguous ambigram ...
| Re: Liar Pendant [message #19661 is a reply to message #19633 ] Tue, 26 October 2010 14:58 UTC |
| dizingof wrote on Mon, 25 October 2010 20:35 | huh? when you wear it it's vertical.. so you cant tell it spells liar.. only when you look at it when its positioned horizontally ..
If you look at it from a 20 degree angle it still says liar. now if you were to move some of the points of the spline (I'm assuming he drew it as a spline) in the z direction, it would look like a swirling piece, and would only be really visible head on.
| Re: Liar Pendant [message #19670 is a reply to message #19661 ] Tue, 26 October 2010 17:13 UTC |
vertical or horizontal... who knows what 'prevaricator' means (apart from google)
