Mr. Robotman
 () 2 Vote(s)
icon1.gif  Mr. Robotman [message #19190] Fri, 15 October 2010 20:56 UTC Go to next message
avatar chris89  is currently offline chris89
**UPDATE**
http://i56.tinypic.com/n6exwx.jpg
http://i56.tinypic.com/2qmzx5l.jpg
http://i55.tinypic.com/2qav0ix.jpg
_______________________________________________
So i made a new model and got it printed. This time it's a robot.
I've decided to have it printed in 20cm high White Detail and make a base for it myself (which i might get around to this weekend).
I've also printed a smaller WSF version for fun and because it was cheap.
some small parts on the White Detail version were broken off when it arrived, but i guess i was pushing the limits with the thickness.
I have to give shapeways some credits for getting that fragile model printed and cleaned! great job guys!!!
Some pictures.
white strong and flexible (15cm)
http://i55.tinypic.com/2j61l55.jpg
white detail (20cm)
http://i55.tinypic.com/125j0nd.jpg
close ups
http://i52.tinypic.com/28mk13s.jpg
http://i52.tinypic.com/644078.jpg
unfortunately these 2 bits were broken, i guess during transport, the rest is fine.
http://i53.tinypic.com/akx5qf.jpg
http://i56.tinypic.com/1g0scg.jpg
cheers
chris
[Updated on: Sun, 07 November 2010 16:30 UTC]
Re: Mr. Robotman [message #19192 is a reply to message #19190 ] Fri, 15 October 2010 22:26 UTC Go to previous messageGo to next message
Very cool design!
www.Craftosterone.com
Re: Mr. Robotman [message #19193 is a reply to message #19190 ] Fri, 15 October 2010 22:38 UTC Go to previous messageGo to next message
avatar Drawn_Steel_Hero  is currently offline Drawn_Steel_Hero
Really nice design - he's got lots of character! Very Happy
I take it you're planning to paint him up?
Andy
Re: Mr. Robotman [message #19196 is a reply to message #19193 ] Sat, 16 October 2010 00:04 UTC Go to previous messageGo to next message
thanks guys.
I was planning on just giving him a coat of gray spraypaint to make him look a bit more like a maquette. However, i am very tempted to give this guy a nice paintjob.
First things first though, making a solid base and somehow attaching him to it.
Re: Mr. Robotman [message #19198 is a reply to message #19190 ] Sat, 16 October 2010 00:53 UTC Go to previous messageGo to next message
No Message Body
[Updated on: Sat, 16 October 2010 00:54 UTC]
Re: Mr. Robotman [message #19323 is a reply to message #19198 ] Mon, 18 October 2010 19:30 UTC Go to previous messageGo to next message
Not sure what happened to that previous post.. ah well.
Important step for finishing your model: Bluetack it to a steak and kidney pie! (contents still in there.. for added weight Wink )
http://i56.tinypic.com/juabyo.jpg
Re: Mr. Robotman [message #19324 is a reply to message #19190 ] Mon, 18 October 2010 19:39 UTC Go to previous messageGo to next message
You know what? I reckon if you emptied out the tasty tasty contents and filled it with something else to weigh it down, that could make a nice little plinth base.
Andy
Re: Mr. Robotman [message #19409 is a reply to message #19324 ] Tue, 19 October 2010 18:48 UTC Go to previous messageGo to next message
That's the plan Very Happy
Started sculpting.. man i need waaay more practise.. anyway work in progress images:
http://i52.tinypic.com/wi0jcx.jpg
http://i53.tinypic.com/33uv4h2.jpg
Re: Mr. Robotman [message #19416 is a reply to message #19409 ] Tue, 19 October 2010 20:02 UTC Go to previous messageGo to next message
avatar jmw326  is currently offline jmw326
That is an awesome design. He needs friends now.
Re: Mr. Robotman [message #19435 is a reply to message #19190 ] Wed, 20 October 2010 13:12 UTC Go to previous messageGo to next message
avatar Sparlin  is currently offline Sparlin
Fantastic! This is exactly what shapeways is perfect for!
Re: Mr. Robotman [message #19472 is a reply to message #19435 ] Wed, 20 October 2010 22:31 UTC Go to previous messageGo to next message
cheers guys.
And yes he does need friends Sad but i'm not sure if my wallet agrees.
update:
http://i53.tinypic.com/2cs8e9d.jpg
http://i52.tinypic.com/29m6sup.jpg
Re: Mr. Robotman [message #19499 is a reply to message #19190 ] Thu, 21 October 2010 15:08 UTC Go to previous messageGo to next message
That's some really nice sculpting there. Smile
Andy
Re: Mr. Robotman [message #20194 is a reply to message #19499 ] Sun, 07 November 2010 16:29 UTC Go to previous messageGo to next message
Man, i can't believe how hard it is to find gray spray primer in guildford, UK.
Finally found it though, at a shop that recently opened.
I have to say getting this thing cleaned was a nightmare. The support material from the printer is everywhere and without a waterjet it just turns into a gritty layer on your model. After a while i was a bit fed up so i decided to just start spraying the model
The cold outside and from the paint did warp the model a bit. Therefore i had to resettle the right foot (as you can see in the picture, some bluetack had to be added).
So i unloaded the Tamiya fine gray primer onto the white detail model. It makes the print lines very obvious, but nothing a couple more coats can't fix.
It pulls out the shapes a lot, and now it finally looks like a proper model Smile i'm very happy with it.
pictures:
Re: Mr. Robotman [message #20238 is a reply to message #19190 ] Mon, 08 November 2010 16:50 UTC Go to previous messageGo to next message
This is a great project... What are you doing your modelling with for the base?
Glenn
Re: Mr. Robotman [message #20255 is a reply to message #20238 ] Mon, 08 November 2010 23:15 UTC Go to previous messageGo to next message
thanks.
The base is a steak and kidney pie container and some supersculpey clay. As you can see i made some mistakes with the clay (temperature changes and rough handling) but it blends in very well with any surface you use it on.
Re: Mr. Robotman [message #20280 is a reply to message #19190 ] Tue, 09 November 2010 11:28 UTC Go to previous message
Oh, yes, recognised the pie tray, but that supersculpey clay I'm not familiar with. Yes, it does seem to blend in very well with the tray. I'd have worried that it would come off.
Glenn
Previous Topic:Gift Cube by OSKAR
Next Topic:Nautilus and Martian War Machines
