OBJ to STL question
OBJ to STL question [message #15915] Wed, 11 August 2010 12:17 UTC Go to next message
avatar shangshangw  is currently offline shangshangw
I am new in 3d printing!
I'm puzzled by the the result of converting obj file to stl
why does what I see in zbrush a smooth surface turn into many obvious triangular shapes? How does this affect the printing result?
I actually went to a LRP facility with one stl file.
I wanted it to be 13cm, but people there told me the file's standard size for production is only 0.50cm.
What should I do? How can I adjust the scale?
For example:
OBJ file
http://img706.imageshack.us/img706/3945/23432560.jpg
STL file
http://img64.imageshack.us/img64/7568/67931142.jpg
Re: OBJ to STL question [message #15917 is a reply to message #15915 ] Wed, 11 August 2010 12:40 UTC Go to previous messageGo to next message
STL is the standard for 3D printing, and is a method of displaying 3D models in polygons. OBJ uses I think T-Splines to display models. Which is why OBJ looks smooth and STL looks well polygonal.
Re: OBJ to STL question [message #15919 is a reply to message #15917 ] Wed, 11 August 2010 13:26 UTC Go to previous messageGo to next message
It is not just the look, right?
is the printing result also polygonal?
A More Comprehensive Answer [message #15920 is a reply to message #15915 ] Wed, 11 August 2010 13:33 UTC Go to previous messageGo to next message
avatar ziusuadra  is currently offline ziusuadra
I thought it would be helpful to try and provide you with a more comprehensive answer, so here goes.
Each of the file formats that you might choose to use (for example, OBJ and STL) is actually storing the object that you have created as a table listing all of its vertices as individual points (X, Y, Z). These are connected to one another to create an assortment of polygons which form the actual shape you are working with (the shape you see after your conversion to STL).
The catch is that some software allows the option of using mathematics to create the illusion of a smoothed surface when the object you are using is displayed on the screen of your monitor (which is the shape you see in your original OBJ file). This is not the 'real' object, just a smoothed interpretation of it. Since what we are printing is the 'real' object, you need to turn off the smoothing effect to see what your design will really look like when printed (how to do this depends on what software you are using at the time). You may need to add more polygons, for example, to create an object that is actually smoother, rather than just looking smoother.
Now to the issue of scale. Since each of the points in your object is stored as an (X, Y, Z) co-ordinate, the numbers have an associated unit, which is different for each type of software you might be using. (This is similar to metric vs. imperial measurements, in that one unit in software may not equal, say, one unit in the real world). To make your object the right size, you need to find out how to convert the units your object is currently in (as an STL) to a real-world measurement in centimetres. Once you calculate the conversion factor, you must then scale the entire object in software so that it is the correct number of STL units to equal the real-world size. (Example - I want my object to be 20cm wide, but my software uses 1 inch units. I know that 1 inch = 2.5 cm, so I make my object 8 inches wide. It is now a 20cm wide object when printed).
To find out exactly how to do all this, consult the documentation for your software (for smoothing and file format specifics) and the online documentation for Shapeways (to find out how to convert to centimetres, how big your object can be, and other design limitations). I hope this helps to answer your questions.
Re: OBJ to STL question [message #15925 is a reply to message #15915 ] Wed, 11 August 2010 14:59 UTC Go to previous messageGo to next message
Depending on the size of the polygons, they will probably show. Some software lets you control the output of the STL. I break mine into as many polygons as I can while keeping under the 50K limit.
Re: A More Comprehensive Answer [message #15928 is a reply to message #15920 ] Wed, 11 August 2010 15:57 UTC Go to previous messageGo to next message
Thank you!
This is very helpful.
But still it seems to be rather difficult to scale things in the exact real world size as you want.
I check else where rhino can actual scale stl model.
So I guess I can make model in max and zbrush than scale in rhino
Do you know how to do that in Rhino then...?
Re: OBJ to STL question [message #15933 is a reply to message #15915 ] Wed, 11 August 2010 16:53 UTC Go to previous messageGo to next message
In rhino, no I don't. There are a few Rhino users here, that I've seen, if you do a search in the forum for Rhino, you may be able to find something or someone that can help.
Re: OBJ to STL question [message #18770 is a reply to message #15915 ] Wed, 06 October 2010 20:09 UTC Go to previous message
Late reply, hope you get it...
It's very simple and accurate to size in Rhino - I do it all the time.
When you start up Rhino you are given many different options as to what units you want your workspace in; I choose the bottom one, millimeters. Now, when you look at your workspace what you see is a grid, like graph paper. Each tiny square represents ONE millimeter, and the larger squares one centimeter.
IMPORT your model.
The model should still be highlighted/selected. If not make sure you do this.
On the menus across the top click on Transform (there are icons you can use but let's keep this simple). Mouse down to Scale then click on the Scale 3-D flyout.
You are asked for an origin point. Click somewhere near your model.
Now you are asked for a scale factor. If you want to reduce your model by 50% type .50, if you want it reduced to ten percent type .10...etc., then hit Enter.
Bingo. Done.
Export to STL and you're ready to upload to Shapeways.
Rhino allows you to do this in different ways, including dragging with your mouse, I just simplified it here.
You can also measure from point to point by clicking on Analyze then Distance. Click on two points in your model and the distance is shown.
Hope that helps.
Glenn
Previous Topic:2 types of material in the same object?
Next Topic:Colour prints from Blender (n00b with many questions)
