Home » Community » 3D modeler needed » Miniature-car wheels
Miniature-car wheels [message #18423] Mon, 27 September 2010 13:07 UTC Go to next message
avatar super-cab  is currently offline super-cab
Hi
I'm looking for the possibilty to make a set "alloy" wheels for miniature modelcar(s).
Those 3 types of wheels I would like to print.
index.php?t=getfile&id=5257&private=0
They must be max. 9 mm diameter. (miniature scale 1:43)
Should this be possible to make, or are they to small ????
Rick
  • Attachment: totaal.jpg
    (Size: 31.59KB, Downloaded 438 time(s))
Re: Miniature-car wheels [message #18429 is a reply to message #18423 ] Mon, 27 September 2010 13:36 UTC Go to previous messageGo to next message
avatar marcobeer  is currently offline marcobeer
It can be done, properly you should consider some detail lost. Min thickness is 1mm, so the spokes going to look a bit bulkier than on the photo. And logo could be a problem.
Are you going to model yourself or are you in need for one.
[Updated on: Mon, 27 September 2010 13:37 UTC]
Re: Miniature-car wheels [message #18430 is a reply to message #18423 ] Mon, 27 September 2010 13:52 UTC Go to previous messageGo to next message
For an item this size, in WSF .7mm should be acceptable. Which it appears only the first would have this problem. I would see the lug holes being a problem. You may have to plan to tool them after wards.
Re: Miniature-car wheels [message #18431 is a reply to message #18429 ] Mon, 27 September 2010 13:53 UTC Go to previous messageGo to next message
marcobeer wrote on Mon, 27 September 2010 14:36
Thanks for reaction.
I was allready affraid about th thinksness of the double spokes of the first wheel.
Maybe it could be made as 1 spoke with a relief-line in the middle wich a can paint dark, so it look like separate spokes.
Loss of logo is not a problem.
I would try to draw myself, (that the most fun I think)
I've been searching for the right program to draw with.
Some I've download (before my PC crashed) I could not get used to.
Now i' ve just got a CAD-program wich can draw 2D.
Suggestions???
Rick
Re: Miniature-car wheels [message #18433 is a reply to message #18431 ] Mon, 27 September 2010 14:14 UTC Go to previous messageGo to next message
Hi Rick
There are a lot of 3d programs out there and al will require some effort to master. Try blender
Re: Miniature-car wheels [message #18435 is a reply to message #18433 ] Mon, 27 September 2010 14:43 UTC Go to previous messageGo to next message
marcobeer wrote on Mon, 27 September 2010 15:14
Hi Rick
You are totally right.
Some effort is needed, but it must also be a little bit understandable.
Robocad (from many many years ago) works still fine for me Embarassed
Thanks for the "blender" suggestion.
I'm downloaded it and will try this after reading the tutorials.
gr Rick
Re: Miniature-car wheels [message #18437 is a reply to message #18423 ] Mon, 27 September 2010 14:53 UTC Go to previous messageGo to next message
Blender will take a lot of getting used to. I still haven't made much of an attempt to be able to use it.
Re: Miniature-car wheels [message #18438 is a reply to message #18437 ] Mon, 27 September 2010 15:09 UTC Go to previous messageGo to next message
Youknowwho4eva wrote on Mon, 27 September 2010 15:53
Oke...
Do you have suggestion for a easier program for me?
Re: Miniature-car wheels [message #18439 is a reply to message #18423 ] Mon, 27 September 2010 15:13 UTC Go to previous messageGo to next message
Easiest I've used is Sketchup. Still to get the shapes you want (the curvature of the spokes) won't be the easiest.
Re: Miniature-car wheels [message #18441 is a reply to message #18439 ] Mon, 27 September 2010 15:21 UTC Go to previous messageGo to next message
Hi Rick,
i've made you a model of one of the rims,
http://www.shapeways.com/shops/helmuths3d
Didn't paid to attention to the detail, all sizes are within reach of 3d printer. Spend bid more time and you can make something better. Don't know if you'll need more detail in it. I make a lot of 1/35 scale object and a lot of curves are lost!
I used 3dsmax
Re: Miniature-car wheels [message #18442 is a reply to message #18441 ] Mon, 27 September 2010 15:59 UTC Go to previous messageGo to next message
marcobeer wrote on Mon, 27 September 2010 16:21
Hi Rick,
I used 3dsmax
Hi
I can't see it Embarassed
Must i look somewhere at your page??
Re: Miniature-car wheels [message #18443 is a reply to message #18442 ] Mon, 27 September 2010 16:11 UTC Go to previous messageGo to next message
you have to go to my shop and you should see it
icon14.gif  Re: Miniature-car wheels [message #18446 is a reply to message #18443 ] Mon, 27 September 2010 16:58 UTC Go to previous messageGo to next message
marcobeer wrote on Mon, 27 September 2010 17:11
yes it's there now.
Thanks Thumbs Up
This gives hope to make something like the originals.
[Updated on: Mon, 27 September 2010 16:59 UTC]
Re: Miniature-car wheels [message #48418 is a reply to message #18423 ] Tue, 15 May 2012 07:24 UTC Go to previous message
avatar kritiana89  is currently offline kritiana89
intresting story behind fitting in those new rings, i found them on ebay, but i didnt know they were oversize by .03 of an inch! we had to grind a little off the tips of the break on each one until they fit right, spent almost all day getting them to fit
Previous Topic:Artist needs a modeller - please give quote
Next Topic:Need a 3D modeler for a mask
