Multiple materials possible in a color model?
icon5.gif  Multiple materials possible in a color model? [message #17837] Thu, 16 September 2010 09:19 UTC Go to next message
avatar Sevensheaven  is currently offline Sevensheaven
I was wondering: is it possible to print multicolor models colored by different materials in stead of textures?
For example, the 3D models in this scene are created using only different materials on selected polygons, no bitmaps:
http://www.sevensheaven.nl/images/producten/voxel-3d-pixel-art-dots-illustration_steve-jobs-statue-monsters-inc-pixar.jpg
Thanks in advance for your answer.
http://metinseven.com — 3D modeler • designer • illustrator
Re: Multiple materials possible in a color model? [message #17844 is a reply to message #17837 ] Thu, 16 September 2010 10:29 UTC Go to previous messageGo to next message
Yes, we also support color by using material definition in the vmrl and x3d.
Kind regards, Arno
Re: Multiple materials possible in a color model? [message #17847 is a reply to message #17844 ] Thu, 16 September 2010 11:32 UTC Go to previous messageGo to next message
Dank je Arno! Smile
Is it necessary to export the model as a VRML or X3D file to make use of multi-material based coloring, or are other 3D formats such as 3ds or Obj supported as well?
Are there any other guidelines I should follow when preparing my model for multicolor printing?
Thanks again.
Re: Multiple materials possible in a color model? [message #17852 is a reply to message #17847 ] Thu, 16 September 2010 13:23 UTC Go to previous messageGo to next message
Hi Sevensheaven,
I love your cartoons, it's good to see you here!
We currently only support VRML and X3D for color models. Also keep in mind that these file formats treat 1 unit as 1 meter, so model small. For the rest: if your preview shows it correctly you should be all set.
If you run into any problems with your project, please get in touch with me: bart@shapeways.com.
Re: Multiple materials possible in a color model? [message #17854 is a reply to message #17852 ] Thu, 16 September 2010 13:59 UTC Go to previous messageGo to next message
Many thanks Bart, I'm flattered to read that you know and like my work, much appreciated.
I will soon prepare and upload my first full-color test model. Can't wait to fully go for Shapeways!
All the best,
Metin
Re: Multiple materials possible in a color model? [message #17962 is a reply to message #17854 ] Fri, 17 September 2010 13:28 UTC Go to previous messageGo to next message
A few more questions, sorry:
- When I create a model, is it necessary to create an opening somewhere in the model, in order to enable removal of the support material?
- Is there a minimal wall thickness for a hollow model?
- If there are only materials with different colors in my VRML97 model, do I still have to pack the model in a Zip file, even if there are no textures?
- Is setting the units in 3ds Max to meters and then scaling the model to the desired size the right way to ensure the correct 3D print dimensions?
Thanks again!
Metin
[Updated on: Mon, 20 September 2010 13:04 UTC]
Re: Multiple materials possible in a color model? [message #17982 is a reply to message #17837 ] Fri, 17 September 2010 17:58 UTC Go to previous messageGo to next message
Update:
I've been busy preparing my first full-color model with multiple materials, but after the upload it shows as black, as if the different materials aren't exported along with the model from 3ds Max.
I've tried the standard VRML97 exporter and the free X3D exporter from Fraunhofer, but both files show up looking all black in the generated Shapeways preview.
When I check both the VRML97 and X3D file in Notepad, there's only one material entry at the start, no multiple materials, as if the 3ds Max exporters only look at the first material from the multi-material set.
I've also got the feeling that the price is too high for a hollow model. I guess the model is regarded as a solid volume.
[Updated on: Fri, 17 September 2010 18:07 UTC]
Re: Multiple materials possible in a color model? [message #17985 is a reply to message #17837 ] Fri, 17 September 2010 18:38 UTC Go to previous messageGo to next message
If you put up the VRML I'll check it out, or if you don't want everyone to see it you can email it to me at youknowwho4eva@gmail.com. What software are you exporting from? Are you using different materials or different color attributes?
Re: Multiple materials possible in a color model? [message #18052 is a reply to message #17985 ] Sun, 19 September 2010 17:24 UTC Go to previous messageGo to next message
loved your work @ Nu.nl!
hope to see printed models from you soon!
icon14.gif  Re: Multiple materials possible in a color model? [message #18083 is a reply to message #17837 ] Mon, 20 September 2010 11:07 UTC Go to previous messageGo to next message
Thanks a lot guys!
In the mean time I've been experimenting some more and had some correspondence with the Shapeways team, so I guess the solution is very near now. When I'm done I'll post my tips over here.
Cheerio,
Metin
Re: Multiple materials possible in a color model? [message #18162 is a reply to message #17837 ] Wed, 22 September 2010 17:29 UTC Go to previous message
Hi again,
In the mean time everything seems to be allright. Here's the result.
What I've learned:
- Always compress your 3D file in a Zip before uploading it, even though the upload info text mentions you can also directly upload WRL files.
- If your model is hollow, be sure to create a hole from the outside to the inner space of the model in order to have the model recognized as hollow in stead of solid. More info about that can be found over here.
Thanks again for offering your help.
Metin
Previous Topic:Cleaning Detail of its Gel gunk
Next Topic:changing color under UV?
