Alumide strength & flexibility
Alumide strength & flexibility [message #17929] Fri, 17 September 2010 02:29 UTC Go to next message
Have there been any videos or experience with alumide flexing. Like what kind of flex would a 1 mm strip give? Is if 50% of the flex of wsf?
[Updated on: Fri, 17 September 2010 02:29 UTC]
Jeff Bare
Industrial Designer
@jbaredesign
Re: Alumide strength & flexibility [message #18023 is a reply to message #17929 ] Sun, 19 September 2010 04:31 UTC Go to previous messageGo to next message
avatar TimberWolf  is currently offline TimberWolf
The amount of flex that a 1mm (assuming thickness) strip would give highly depends on its length and width, and which axis you bend it on. Search for "Moment of Inertia" online to find out more Razz
From the material datasheets, Alumide seems to be slightly more than 2x stiffer (see the tensile/flexural modulus) than WSF. However, do note that this comes at a significantly lower enlongation-to-break (4% Alumide vs 25% WSF) so if your part is required to yield significantly, then WSF might be a better option.
Cheers
QX
Re: Alumide strength & flexibility [message #18025 is a reply to message #18023 ] Sun, 19 September 2010 12:12 UTC Go to previous messageGo to next message
avatar chris89  is currently offline chris89
Alumide is the first and only strip in the material sample kit that snapped Smile just to give you an idea of it's flex.
Re: Alumide strength & flexibility [message #18056 is a reply to message #17929 ] Sun, 19 September 2010 19:08 UTC Go to previous messageGo to next message
Thanks, that helps. So for this piece, http://www.shapeways.com/model/142657/canvas_wrap___pattern_ 1.html?gid=ug3024
Look at the video on that page. Obviously I can't flex it like that, but it should flex enough to get on the iPad, yeah?
Jeff Bare
Industrial Designer
@jbaredesign
Re: Alumide strength & flexibility [message #18071 is a reply to message #17929 ] Mon, 20 September 2010 05:28 UTC Go to previous message
Hmm, I'd be cautious.
Although WSF/Alumide will gain significant flexibility if you heat them up a bit. If you find that the fitment is slightly off, and it might snap if you try and flex the part anymore, put it in a pot of boiling water for a minute or two. It'll soften it up for clipping to the ipad, and go stiff again as it cools. The nylon has a memory, so you shouldn't have to worry about any irreversible warping.
That cover will look pretty smart in Alumide. I say go for it.
Previous Topic:Densities?
Next Topic:Cleaning Detail of its Gel gunk
