Java works but Creator does not
Java works but Creator does not [message #1602] Fri, 17 October 2008 15:33 UTC Go to next message
avatar dkaufman1  is currently offline dkaufman1
In Vista, with Firefox 3, IE 7 and Chrome the Creator application will download and install and then the Yumatech piece fails and closes the whole application. There is no log file that I know of to send off the error report, but I am unable to get the Creator working.
Any help?
Re: Java works but Creator does not [message #1620 is a reply to message #1602 ] Sun, 19 October 2008 06:40 UTC Go to previous messageGo to next message
I have no idea what's going on, but I've forwarded your message to our development team.
Re: Java works but Creator does not [message #1622 is a reply to message #1620 ] Sun, 19 October 2008 14:22 UTC Go to previous messageGo to next message
Bart -
Thanks...I will watch this thread for any help I can provide. I guess I miss out on the 66% off deal, huh?
Dave
Re: Java works but Creator does not [message #1624 is a reply to message #1622 ] Sun, 19 October 2008 14:45 UTC Go to previous messageGo to next message
If you can, open the Java Console and see what error logs may be there.
From memory (I'm away on the office and on a Mac as I write this), go to your Start menu and go to "run". In the text field, type "javaws -viewer". This should display a small application with several tabs. One of those tabs should be logging and console options. Select the option that says "Show console always" and then when you next start the creator you should get an independent set of logs.
The creator should not be exiting directly without some manual input - either Java will tell you something failed and you have to click a button to close, or that your login failed (after asking for a username and password 3 times) and it then shuts down. I can't think of any condition under which java will just immediately exit without giving you a chance to see what is going on.
Re: Java works but Creator does not [message #1627 is a reply to message #1624 ] Sun, 19 October 2008 15:39 UTC Go to previous messageGo to next message
Thanks...at least for helping show the error....
here is the copy and paste:
Java Web Start 1.6.0_07
Using JRE version 1.6.0_07 Java HotSpot(TM) Client VM
User home directory = C:\Users\dkaufman1
c:   clear console window
f:   finalize objects on finalization queue
g:   garbage collect
h:   display this help message
m:   print memory usage
o:   trigger logging
p:   reload proxy configuration
q:   hide console
r:   reload policy configuration
s:   dump system and deployment properties
t:   dump thread list
v:   dump thread stack
0-5: set trace level to <n>
java.lang.UnsatisfiedLinkError: no jogl in java.library.path
	at java.lang.ClassLoader.loadLibrary(Unknown Source)
	at java.lang.Runtime.loadLibrary0(Unknown Source)
	at java.lang.System.loadLibrary(Unknown Source)
	at com.sun.opengl.impl.NativeLibLoader.loadLibraryInternal(NativeLibLoader.java:189)
	at com.sun.opengl.impl.NativeLibLoader.access$000(NativeLibLoader.java:49)
	at com.sun.opengl.impl.NativeLibLoader$DefaultAction.loadLibrary(NativeLibLoader.java:80)
	at com.sun.opengl.impl.NativeLibLoader.loadLibrary(NativeLibLoader.java:103)
	at com.sun.opengl.impl.NativeLibLoader.access$200(NativeLibLoader.java:49)
	at com.sun.opengl.impl.NativeLibLoader$1.run(NativeLibLoader.java:111)
	at java.security.AccessController.doPrivileged(Native Method)
	at com.sun.opengl.impl.NativeLibLoader.loadCore(NativeLibLoader.java:109)
	at com.sun.opengl.impl.windows.WindowsGLDrawableFactory.<clinit>(WindowsGLDrawableFactory.java:60)
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Unknown Source)
	at javax.media.opengl.GLDrawableFactory.getFactory(GLDrawableFactory.java:106)
	at javax.media.opengl.GLCanvas.chooseGraphicsConfiguration(GLCanvas.java:520)
	at javax.media.opengl.GLCanvas.<init>(GLCanvas.java:131)
	at org.j3d.aviatrix3d.output.graphics.SimpleAWTSurface.init(SimpleAWTSurface.java:264)
	at org.j3d.aviatrix3d.output.graphics.SimpleAWTSurface.<init>(SimpleAWTSurface.java:179)
	at org.j3d.aviatrix3d.output.graphics.SimpleAWTSurface.<init>(SimpleAWTSurface.java:130)
	at org.j3d.aviatrix3d.output.graphics.SimpleAWTSurface.<init>(SimpleAWTSurface.java:47)
	at udesign.editor.BaseEditor.setupAviatrix3D(BaseEditor.java:236)
	at udesign.editor.BaseEditor.initialize(BaseEditor.java:152)
	at udesign.editor.fruitconfessions.FruitConfessionsEditor.initialize(FruitConfessionsEditor.java:109)
	at udesign.editor.ModelView.selectionChanged(ModelView.java:313)
	at org.chefx3d.model.BaseWorldModel.changeSelection(BaseWorldModel.java:272)
	at udesign.editor.ModelView.setTool(ModelView.java:164)
	at org.chefx3d.view.ViewManager.setTool(ViewManager.java:169)
	at udesign.UDesignViewer.<init>(UDesignViewer.java:346)
	at udesign.UDesignViewer.main(UDesignViewer.java:1153)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at com.sun.javaws.Launcher.executeApplication(Unknown Source)
	at com.sun.javaws.Launcher.executeMainClass(Unknown Source)
	at com.sun.javaws.Launcher.doLaunchApp(Unknown Source)
	at com.sun.javaws.Launcher.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
#### Java Web Start Error:
#### null
java.lang.reflect.InvocationTargetException
Caused by: java.lang.UnsatisfiedLinkError: no jogl in java.library.path
	... 9 more
<?xml version="1.0" encoding="utf-8"?>
<!-- JNLP File for the Shapeways Application -->
<jnlp spec="1.5+" codebase="http://www.shapeways.com/modules/udesign/ext/client/" href="http://www.shapeways.com/modules/udesign/utils/openclient.php?model=6571&editor=2&iep=g835hf7qim9j9t070ldjcb34d0">
  <information>
    <title>Shapeways Editor</title>
    <vendor>Yumetech, Inc.</vendor>
    <homepage href="http://www.shapeways.com"/>
    <description>Shapeways Application</description>
    <shortcut online="false">
      <menu submenu="Yumetech Applications"/>
    </shortcut>
  </information>
  <security>
    <all-permissions/>
  </security>
  <resources>
    <j2se version="1.5+" java-vm-args="-Xmx512M -XX:MaxDirectMemorySize=256M -Dsun.java2d.noddraw=true" href="http://java.sun.com/products/autodl/j2se" />
    <jar href="lib/udesign_1.2.3.jar" />
    <jar href="lib/aviatrix3d-all_2.0.0.jar" />
    <jar href="lib/chefx3d_core_2.0.0.jar" />
    <jar href="lib/j3d-org-all_0.9.0.jar" />
    <jar href="lib/vecmath.jar" />
    <jar href="lib/fastinfoset_1.2.2.jar" />
    <jar href="lib/xj3d-norender_2.0.0.jar" />
    <jar href="lib/xj3d-interchange-loader-av3d_2.0.0.jar" />
    <jar href="lib/uri.jar" />
    <jar href="lib/vlc_uri.jar" />
  </resources>
  <resources>
    <extension name="jogl" href="http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jnlp" />
  </resources>
  <application-desc main-class="udesign.UDesignViewer">
    <argument>modelID=-4</argument>
    <argument>sessionID=g835hf7qim9j9t070ldjcb34d0</argument>
    <argument>soapServer=http://www.shapeways.com</argument>
    <argument>backgroundColor=0.57 0.78 0.93 0.8 0.8 0.8</argument>
  </application-desc>
</jnlp>
Re: Java works but Creator does not [message #1628 is a reply to message #1627 ] Sun, 19 October 2008 17:03 UTC Go to previous messageGo to next message
Hmmm. looks like the OpenGL bindings failed to install properly. Typically this happens if the install is interrupted part way through (eg connection drop or hitting Cancel somewhere along the install).
The only real way to correct this is to get your hands dirty in the Java cached files and setup to clear out the JOGL install and start again. In that first viewer, there should be a Java Application Cache Viewer. Bring that up and go to the User panel. Down the bottom you will find a "Java Binding to OpenGL" and "Gluegen Runtime". You'll need to remove both of those (and anything else Java says you should clean out too). Then restart the creator.
Re: Java works but Creator does not [message #1630 is a reply to message #1628 ] Sun, 19 October 2008 21:35 UTC Go to previous message
Co-Founder
The process is explained here:
http://www.java.com/en/download/help/5000020300.xml
Hope it helps
Peter
Previous Topic:Order Options
Next Topic:Contest notifacation
