Home » Support » 3D Design »
Help with blender model
Help with blender model [message #15956] Wed, 11 August 2010 23:51 UTC Go to next message
avatar 3DKits  is currently offline 3DKits
I have been trying to get the non manifold issue worked out on this model but cant seem to get it. I am using blender for this model. Any help would be great!
  • Attachment: URN.obj
    (Size: 2.81MB, Downloaded 111 time(s))
Re: Help with blender model [message #15960 is a reply to message #15956 ] Thu, 12 August 2010 02:47 UTC Go to previous messageGo to next message
OK, I took a close look at the non-manifold bits. Hit shft-ctrl-M to select only the non-manifold vertices, and then shift-H to hide all the other vertices, then zoom in on one group. The groups are at the tips of those long curved shapes. At the very tip of each one, there is an unconnected vertex with a ring of other unconnected vertices around it, and the actual surface has a jagged hole in the end around them.
Use the Mesh->Scripts->Clean Meshes scripts to get rid of the free vertices. Then you'll have to go into each of the holes and close it up, presumably by making faces that complete the surface. There might be a faster way to do that.
Re: Help with blender model [message #15968 is a reply to message #15960 ] Thu, 12 August 2010 08:23 UTC Go to previous messageGo to next message
Thanks for the help! I am still trying to learn this program, knowing how to do this helps alot!
Thanks again!
Re: Help with blender model [message #15981 is a reply to message #15968 ] Thu, 12 August 2010 13:19 UTC Go to previous messageGo to next message
I'm still learning it too (believe me, I am *FAR* from an expert at Blender). The more you learn about it, the cooler it gets. That's probably true of a lot of complicated programs. As you tinker with it, you'll stumble upon more and more of its features.
Re: Help with blender model [message #15984 is a reply to message #15956 ] Thu, 12 August 2010 16:51 UTC Go to previous message
avatar Cre83D  is currently offline Cre83D
Very nice to find some Blender mates Smile
I have watched your urn, looks nice.
Created with 3 objects.
Made the main object hollow for you.
Some correction are simple to fix with Netfabb.
But with blender also good to do.
I hope you like it.
Good luck
Greetings
Peter
Previous Topic:Objects not exported to STL
Next Topic:cutting text out of an object in blender
