 () 1 Vote(s)
Tea Dying [message #2400] Thu, 08 January 2009 17:18 UTC Go to next message
Here is a photo of my Nocturnal Timepiece printed in White Detail Material after tea dying:
http://www.shapeways.com/modules/udesign/utils/openfile.php?id=12075&f=photos/photo1056.jpg
This piece was put in a strong cup of cold Red Rose tea overnight. Afterwards, I used a paper napkin to dry and buff it.
I love the warm aged look the tea dying gives the item!!! This piece is now permanently dyed. I does not wash off, even when scrubbed. Not even a little.
I also tried it on a small greenman bead made of the transparent detail material. It works just as nicely and gives the piece a nice aged amber look.
http://www.shapeways.com/modules/udesign/utils/openfile.php?id=5622&f=photos/photo1057.jpg
(ADDITIONAL NOTE 04/14/09: Tea Dying does not take on the SWF material)
-Whystler
[Updated on: Tue, 14 April 2009 12:41 UTC]
Re: Tea Dying [message #2402 is a reply to message #2400 ] Thu, 08 January 2009 17:41 UTC Go to previous messageGo to next message
avatar bvicarious  is currently offline bvicarious
Awesome!
Re: Tea Dying [message #2411 is a reply to message #2400 ] Fri, 09 January 2009 12:31 UTC Go to previous messageGo to next message
That is indeed cool!!!
I was about go to shopping to try your fabric dye idea too...just don't know whereabouts I could go to get some...
Re: Tea Dying [message #2415 is a reply to message #2411 ] Fri, 09 January 2009 16:02 UTC Go to previous messageGo to next message
I got my RIT dyes from Zellers ... It's a Canadian department store, so I don't know if you've heard of it. Sometimes you can find fabric dyes in hardware stores (like Canadian Tire) ... but I assume you would be able to source this dye from Walmart, or stores that sell fabric and crafts.
I just searched the Walmart website now .. and there is no fabric dye on the site, but I did find this:
http://www.dharmatrading.com/dyes/
Now, remember that I used RIT dyes. If you use any other dye, you'll have to do your own tests about how much you need for it to look light or dark enough.
Aha, here is the RIT dye site:
http://www.ritdye.com/home.lasso
-Whystler
[Updated on: Fri, 09 January 2009 16:07 UTC]
Re: Tea Dying [message #2421 is a reply to message #2415 ] Fri, 09 January 2009 23:40 UTC Go to previous messageGo to next message
Now we really are polar opposites (Australia here).
Just got an idea I might try out today but afraid it'll probably 'wash off'...
Soft drinks! Fanta...Coke...etc have lots of colouring in them...
Might as well try
Hard drinks! Red wine! Bourbon!
Hmmm the possibilities... will report back Smile
Re: Tea Dying [message #2427 is a reply to message #2421 ] Sun, 11 January 2009 01:03 UTC Go to previous messageGo to next message
ooOOOHhhhhh red wine .... It does a good number on livingroom carpet, so why not plastic?
-Whystler
Re: Tea Dying [message #2609 is a reply to message #2400 ] Fri, 23 January 2009 15:15 UTC Go to previous messageGo to next message
avatar lorddarthvik  is currently offline lorddarthvik
That Tea Dying looks great! I´ve seen the picture of your nocturnal many times but always thought it was spray painted Smile
About the Coke, I wouldn´t try it! Cokes made up of a lot of acid and sugar, sugars gonna make your item sticky, and the acid may melt it. You can try, but don´t be dissapointed if your item melts into it under 2-3 nights! I would go for some cheap alternative of Fanta and such drinks, one which has lots of coloring additives in it. The ones that even paint your tongue red or yellow would probably make a better paint finish.
Red wine sounds good, the alcohol probably doesn`t hurt the material. I hope someone has a piece to try it on, so we can see if it works!
(ps: coke can even melt rubber a bit, in RC car racing we used coke to make tha tarmac grip better! Also if you have an old tooth laying around, you can put it into some coke, wait a few days, and then try to find it. It will dissolve. I never believed this one myselfs until I tried...)
Re: Tea Dying [message #2756 is a reply to message #2609 ] Sat, 31 January 2009 12:15 UTC Go to previous messageGo to next message
avatar rakkar  is currently offline rakkar
maybe you can try using coffee
Re: Tea Dying [message #2758 is a reply to message #2756 ] Sun, 01 February 2009 00:14 UTC Go to previous messageGo to next message
Since the last post, I have tried both coffee and red wine. The coffee looks pretty much identical to the tea dying.
The red wine dye was a purplish-reddish-brownish.. very nice. I'll add pictures soon.
-Whystler
Re: Tea Dying [message #2760 is a reply to message #2400 ] Sun, 01 February 2009 03:47 UTC Go to previous messageGo to next message
I tried fanta and red wine as well Smile
Fanta came out a bit botchy, red wine was consistent and pretty decent.
Re: Tea Dying [message #2781 is a reply to message #2760 ] Mon, 02 February 2009 21:59 UTC Go to previous messageGo to next message
hey Mad,
What material did you dye?
I tea died and coffee died white detail nicely. I tea died SWF with a blotchy/non existant result. I wine died transparent detail nicely, but I would like to see the wine dye on white detail too.
-Whystler...
Re: Tea Dying [message #3759 is a reply to message #2400 ] Sat, 04 April 2009 21:16 UTC Go to previous messageGo to next message
avatar Kitty  is currently offline Kitty
I think any food-coloring would do Smile
I use food-coloring to dye PU resins when i need a colored cast.
I think it also would work on the plastics that shapeway uses.
If it can absorb tea, it can absorb any foodcolor diluted in water.
Probably inks for fountainpens diluted in some water will work as well and they sell that in different colors as well.
I think that would even work better than foodcolors.
[Updated on: Sat, 04 April 2009 21:19 UTC]
Re: Tea Dying [message #3907 is a reply to message #2400 ] Mon, 13 April 2009 05:06 UTC Go to previous messageGo to next message
avatar Dark  is currently offline Dark
looks good, what process do u guys use to actualy dye the part?
ive dyed stuff in the past and we always do that in boiling water.. the part will take more color that way
is that the method used for the parts we see in the pic or it was made at room temp?
i will get my first batch of part printed soon, and it is sure one of the first thing i will try
im looking to get a deep/opac black color for the WFS and the WD material
Re: Tea Dying [message #3908 is a reply to message #3907 ] Mon, 13 April 2009 14:10 UTC Go to previous messageGo to next message
For tea dying, I put two tea bags into a very large cup or small bowl, add hot water from the kettle, and let it steep.
For tea, it doesn't seem like hot water makes much difference in the dying process. So I like to let it cool so as not to compromise the material. I cool it by letting it sit, or sometimes chilling in the refridgerator for a short amount of time. Other times, if I'm not looking for a strong tea finish, I add cool water.
However, for fabric dyes, it's best to use hot water. RIT dies instructions suggest boiling the bath on the stove and dipping your fabric in while it is still very hot. I don't recommend this, because the colour becomes VERY deep. If you do this with purple, for instance, you will make your piece black.
Instead, use a dye bath of boiled water from the kettle, and place this in a container on the counter. Once the dye bath is mixed (about a 1/4 of a RIT packet per cup), then dip your item into the bath for less than 5 seconds. That's right *five seconds* ... or 1/12th of a minute. Got it? Smile A very very short time. And then you will get close to the colour of your dye, if not a bit darker.
I suppose for black dye, it wouldn't matter really because you want black, and you can't really get any deeper.
Good luck. Again, from my experience, RIT dyes are the way to got for colour, and for black.
-Whystler
Re: Tea Dying [message #3909 is a reply to message #3908 ] Tue, 14 April 2009 07:06 UTC Go to previous messageGo to next message
avatar Marleen  is currently offline Marleen
hi Whystler,
Do you use magic tea bags? One of my prints in WSF has been in a tea solution for three days now and nothing really happened besides making it a bit yellowish... (3 bags english breakfast tea)
If tonight it still didn't work, I think I'll try the coffee.
Bye
Marleen
Re: Tea Dying [message #3910 is a reply to message #3909 ] Tue, 14 April 2009 08:34 UTC Go to previous messageGo to next message
avatar daddymack  is currently offline daddymack
Marleen wrote on Tue, 14 April 2009 07:06
hi Whystler,
lol, I thought the the same thing when Whystler first posted this thread. The nocturnal has a real magical charm tea dyed, my stuff ended up just looking dirty...
Re: Tea Dying [message #3913 is a reply to message #3910 ] Tue, 14 April 2009 12:38 UTC Go to previous messageGo to next message
I guess you all didn't see this in a follow up post here Smile I have only tea died white detail and transparent detail with success. I had nearly no success tea dying the SWF material. Sorry I didn't make that clear in the very first post.
However, the SWF material colours quite strongly with fabric dyes.
Magic Tea Bags no ... but with magic mushrooms, you can turn anything every colour Smile
-Whystler
[Updated on: Tue, 14 April 2009 12:39 UTC]
Re: Tea Dying [message #3924 is a reply to message #3913 ] Wed, 15 April 2009 08:33 UTC Go to previous messageGo to next message
Razz LOL
Thank you... yes I missed your remark. Well, I think I am go to buy some dye. The coffee didn't work either. It just looks ugly now. If that doesn't work, I'll think I will make daddymack happy, by buying a new loverslight.
Bye
Marleen
Re: Tea Dying [message #3925 is a reply to message #2400 ] Wed, 15 April 2009 08:49 UTC Go to previous messageGo to next message
Mmm... Muushroooms... Now I understand Cool
Re: Tea Dying [message #4336 is a reply to message #3908 ] Sun, 10 May 2009 07:11 UTC Go to previous messageGo to next message
Whystler wrote on Mon, 13 April 2009 14:10
-Whystler
thanks Whystler, that sound good
thats what i use to dye my stuff, RIT dye
i will post my results once i get my first run of part
(are we not supose to get a tracking # once the order is printed and shipped? ordered 1 week ago and still havent had any news yet, no mail, no tracking #.. nothing!?! Confused )
Re: Tea Dying [message #5192 is a reply to message #2400 ] Sun, 12 July 2009 00:18 UTC Go to previous messageGo to next message
I tried red wine on WSF, it barely had any affect after half an hour. The piece is just barely noticably pink.
Re: Tea Dying [message #14616 is a reply to message #5192 ] Sat, 10 July 2010 16:40 UTC Go to previous messageGo to next message
avatar gumball  is currently offline gumball
Has anyone tried a powered drink mix like Kool-Aid or any of the generics that have tons of coloring? I've got that stuff on my shirt in the past and it stains pretty good.
Re: Tea Dying [message #14617 is a reply to message #2400 ] Sat, 10 July 2010 17:40 UTC Go to previous messageGo to next message
avatar Drawn-Steel Hero  is currently offline Drawn-Steel Hero
I wondered about that myself. I'm not even sure they're allowed to sell anything with that much colouring over here, but I've heard of cases where people have successfully Kool-Aid after actual dyes have failed.
Re: Tea Dying [message #15138 is a reply to message #14617 ] Fri, 23 July 2010 20:20 UTC Go to previous messageGo to next message
I put a piece of SWF and White Detail in a noxiously strong red fruit punch solution.
SWF was untouched.
White Detail was slightly pink.
FYI.
[Updated on: Sat, 24 July 2010 06:32 UTC]
Re: Tea Dying [message #15142 is a reply to message #2400 ] Fri, 23 July 2010 20:52 UTC Go to previous messageGo to next message
avatar jasolo  is currently offline jasolo
About tea dying, I have found that it works better in Detail material with complex designs. But when you have flat surfaces and were well aligned in the 3d printer, they won't get a strong dying and a fingernail will be enough to remove most of it.
I'm not sure if the reason is that smooth surfaces don't have holes to protect the dye or maybe the dye affects specially the support material that get stuck to the model and that it's easy to remove in smooth and "well aligned" surfaces.
Re: Tea Dying [message #15169 is a reply to message #15142 ] Sat, 24 July 2010 06:33 UTC Go to previous message
Tried my bit of WSF in the same tea that dyed a White Detail piece earlier today. Again, nothing.
Previous Topic:Gold Plating 420 SS+Bronze?
Next Topic:Removing Printing Powder from WSF
