| categories question [message #14563] Fri, 09 July 2010 08:56 UTC |
I'm just getting round to fiddling with the new categories... is it true that I can select only one category, or is the interface playing up? Using firefox on mac.
For some of my models it seems I can't change the default at all...
www.michielcornelissen.com
twitter: @michiel_ontwerp
| Re: categories question [message #14564 is a reply to message #14563 ] Fri, 09 July 2010 09:40 UTC |
Same problem for me. Additionally, I have to switch to IE 8 to be able to add my models into categories . These menus simply don't work for me on win 7 Firefox 3.6.6 (loading blue page shows up and nothing happens).
| Re: categories question [message #14568 is a reply to message #14563 ] Fri, 09 July 2010 09:44 UTC |
Michiel,
you should be able to add 2 categories to each product
| Re: categories question [message #14569 is a reply to message #14563 ] Fri, 09 July 2010 10:45 UTC |
It seems I can choose one category and a subcategory; and one where I'm stuck in the main category. Or something, I doesn't seem to behave consistently.
| Re: categories question [message #14572 is a reply to message #14569 ] Fri, 09 July 2010 10:52 UTC |
What is probably happening : models where automatically added to the appropriate sub-categories. (without tagging the main parent category)
So probably one of the sub-categories is still tagged, preventing you from adding new ones.
Whoops never mind
[Updated on: Fri, 09 July 2010 21:00 UTC] - Artist / Engineer / Designer / Shopowner / Volunteer / Moderator -
| Re: categories question [message #14573 is a reply to message #14563 ] Fri, 09 July 2010 11:14 UTC |
Michiel, can you tell me for which model ID's, you got the problems?
Last tuesday all models that had only the subcategorie chosen were also added to the appriopiate parent categories, so that problem should have been solved.
I will also look into the problems with the 'hanging' blue overlay in Firefox.
| Re: categories question [message #14598 is a reply to message #14573 ] Fri, 09 July 2010 18:27 UTC |
Michiel,
Once the first category/sub-caterory is selected, did you try checking directly the second sub-category box without checking the second category?
| Re: categories question [message #14599 is a reply to message #14598 ] Fri, 09 July 2010 18:45 UTC |
| Magic wrote on Fri, 09 July 2010 18:27 | Michiel,
Brilliant magic - that seems to work!
| Re: categories question [message #14602 is a reply to message #14599 ] Fri, 09 July 2010 18:49 UTC |
Now what we know what the work-around is, I am convinced Shapeways team will soon fix the bug...
