Home » Community » Post Production Techniques » Spray paint effect with Uni Posca markers
Spray paint effect with Uni Posca markers [message #11126] Fri, 26 March 2010 13:58 UTC Go to next message
avatar ibec  is currently offline ibec
Since I discovered Uni Posca markers while custom finishing a Kidrobot DIY Munny, I use them whenever I can. They give vibrant colors to almost any object. So when the next Alumide jacuzzi model arrived, I gave it a Uni Posca finishing. I've also used it on WSF, which works great as well.
Here's a link to the original model: http://bit.ly/swjacuzzi2
By the way, I order the markers straight from Japan via eBay. Here's a reliable and fast supplier: http://bit.ly/uniposca
index.php?t=getfile&id=3075&private=0
  • Attachment: uniposca.jpg
    (Size: 541.50KB, Downloaded 1315 time(s))
Re: Spray paint effect with Uni Posca markers [message #11127 is a reply to message #11126 ] Fri, 26 March 2010 14:01 UTC Go to previous messageGo to next message
And this is my "Avatar" Munny Smile
index.php?t=getfile&id=3076&private=0
Re: Spray paint effect with Uni Posca markers [message #11160 is a reply to message #11127 ] Sat, 27 March 2010 13:33 UTC Go to previous messageGo to next message
have you tried these markers on other materials? like White Detail?
Aut Viam Inveniam Aut Faciam
Re: Spray paint effect with Uni Posca markers [message #11178 is a reply to message #11160 ] Sun, 28 March 2010 08:08 UTC Go to previous messageGo to next message
avatar Schorhr  is currently offline Schorhr
Real neat!
Could you post a close up / macro of the painted material (wsf)?
Are there metalic colors available, too?
Re: Spray paint effect with Uni Posca markers [message #11198 is a reply to message #11126 ] Mon, 29 March 2010 06:44 UTC Go to previous messageGo to next message
So far, I worked with the WSF, Robust and Alumide materials. The ones that are porous - like WSF and Alumide - give the best and fastest results when working with these markers. This will probably apply to the Detail material as well.
The kids did some Uni Posca finishing on the models below. The Christmas ball is WSF and the other two are Robust. WSF looks good after a single finish, whereas the Robust material needs multiple layers for good coverage. The third picture is a close up of the Alumide jacuzzi. And yes, metalic colors exist as well, they have a kind of Alumide look. Plus, you can always give it an additional lacquer finish.
index.php?t=getfile&id=3097&private=0
Re: Spray paint effect with Uni Posca markers [message #11567 is a reply to message #11126 ] Fri, 09 April 2010 15:25 UTC Go to previous messageGo to next message
The kids keep using these markers on the printed models. I should ask the SW staff to open an extra "post production" department Wink
http://bit.ly/heartheadmini
index.php?t=getfile&id=3214&private=0
[Updated on: Mon, 12 April 2010 07:13 UTC]
Re: Spray paint effect with Uni Posca markers [message #11987 is a reply to message #11126 ] Wed, 21 April 2010 22:11 UTC Go to previous messageGo to next message
So, I was too impatient to order those paint markers...
So I used a highlighter.
index.php?t=getfile&id=3362&private=0
http://www.shapeways.com/model/86170/iphone_movie_stand.html
it actually worked pretty good. I just "painted" my other iPhone stand with a blue highlighter and that worked pretty well. To get the black, I used a fountain pen. If you use an ink that is super thin like fountain ink, go really really easy on it. It really wanted to bleed everywhere.
Re: Spray paint effect with Uni Posca markers [message #13812 is a reply to message #11126 ] Sat, 19 June 2010 12:14 UTC Go to previous messageGo to next message
Wow great tip. I'll need to get my hands on some to try.
(Found a lot cheaper from other sellers on eBay...going to buy a set now...)
Re: Spray paint effect with Uni Posca markers [message #13813 is a reply to message #13812 ] Sat, 19 June 2010 12:38 UTC Go to previous messageGo to next message
If you live in the USA, I found a source where you can buy individual markers. Maybe not cheaper, but good if you just want to try out a few colors. I ordered some this week and they came in only 2 days with $2.50 shipping!
http://www.durablesupply.com/pospainmar.html
Re: Spray paint effect with Uni Posca markers [message #13815 is a reply to message #13813 ] Sat, 19 June 2010 16:43 UTC Go to previous message
Officeworks in Australia sells them individually too. 8mm for $5.99 AUD, going to get one first.
Previous Topic:Protecting spray coating for WSF ?
Next Topic:Washing White Detail?
