Home » Support » 3D Design » Galatean Dream for real
Galatean Dream for real [message #1267] Tue, 09 September 2008 19:25 UTC Go to next message
avatar aws357  is currently offline aws357
Shocked Look a the bust. Eh. The bust... well you understand what I mean Smile
(don't mind the crappy keyboard on the background, it double as kitchen sometimes Embarassed )
http://www.shapeways.com/modules/udesign/utils/openfile.php?id=3672&f=photos/photo249.jpg
So, the problem is : the very thin hairstrand didn't pass very well. Probably too small.
[Updated on: Tue, 09 September 2008 19:27 UTC]
Re: Galatean Dream for real [message #1362 is a reply to message #1267 ] Thu, 18 September 2008 20:24 UTC Go to previous messageGo to next message
I think it looks great. But I actually I like your model as well. Smile
Model features or details only show up when they are 0.1mm in White Strong & Flexible. At all points the model needs be at least 0.25mm thick to insure the integrity of the model.
For anyone interested you can see the 3D model at http://www.shapeways.com/model/3672/galatean_dream.html
Cheers!
Robert
Re: Galatean Dream for real [message #1363 is a reply to message #1362 ] Fri, 19 September 2008 06:00 UTC Go to previous messageGo to next message
robert wrote on Thu, 18 September 2008 16:24
Hi Robert,
I'm confused by your details. Were they a typo?
I did get the impression that the detail is limited to .1 millimeters from other posts here.
But I was told that walls/thicknesses should be 2-3 millimeters thick. And you have written .25 millimeters thick. Was this a typo?
-Whystler
Re: Galatean Dream for real [message #1367 is a reply to message #1363 ] Fri, 19 September 2008 19:25 UTC Go to previous messageGo to next message
Hi Whystler,
No, it was not a typo. The subject is actually quite complicated. We need to make a tutorial on this.
With White Strong & Flexible you can build walls of 0.25mm thick. The problem they are not very strong. Just imagine two cubes of 2x2x2 cm connected together with a bar of 5 cm wide and 0.25x0.25 mm thick. If you pick it up it will most certainly break. Let alone that we have to ship it to you. That is the reason that the common statement is 2-3 mm.
Does that make sense?
Cheers!
Robert
Re: Galatean Dream for real [message #1371 is a reply to message #1267 ] Fri, 19 September 2008 22:38 UTC Go to previous messageGo to next message
Ohhhhhhh kay, got it Smile
The printer will not print walls thinner than .25 mm.
But if the printer prints walls smaller than 2mm, there is risk of breakage. If the printer prints walls as thin as .25 mm, breakage is pretty much assured .
Is that right?
-Whystler
Re: Galatean Dream for real [message #1377 is a reply to message #1371 ] Sun, 21 September 2008 22:01 UTC Go to previous message
Yes, you got! Smile
Cheers!
Robert
Previous Topic:Model Converter
Next Topic:(HUGE) help needed to produce mutant vehicle
