Home » Support » 3D Design » hollow weirdness
hollow weirdness [message #13483] Wed, 09 June 2010 04:48 UTC Go to next message
avatar sector0  is currently offline sector0
I am new to shapeways and have uploaded a few models to test this out. I use Blender 2.49a on Ubuntu and had a weird export issue with this model I want to print. I exported this simple mesh to STL with dimensions somewhere around 6 cm/ 6cm/ 1.4 cm but very empty in the middle (a M letter with a T flipped 90 degrees). I had hollowed it out by using the extrude method and made sure it was all manifold and nice. When I uploaded it, it is saying it will cost around $124. Played around for hours and finally ditched the extruded internals and uploaded... it came out to $82.... I cannot figure out what is going on and if I am going crazy. I double checked the normals on the inside and they are pointing in and the external face normals are pointing out.
Not sure if this is normal pricing or if something is just seriously wrong with my model.
Any help?
Eric
Re: hollow weirdness [message #13484 is a reply to message #13483 ] Wed, 09 June 2010 05:57 UTC Go to previous messageGo to next message
avatar jasolo  is currently offline jasolo
I get 54$ for your model with Shapeway Calculator 0.7 and WS&F material. Anyway, you could reduce wall thickness from 2mm to 1mm, so the cost goes to 26$ (again WS&F).
Also, you should make a hole on the three bases of the model to permit the residual material to go out after the printing.
Re: hollow weirdness [message #13495 is a reply to message #13484 ] Wed, 09 June 2010 15:51 UTC Go to previous messageGo to next message
But I don't understand why shapeways is not showing the same. I upload that exact STL and it is coming out at $124 (with WS&F).
Thanks for the tip on the holes, I was hoping to get there but after I uploaded this stage of the model and saw the price I couldn't continue.
Re: hollow weirdness [message #13533 is a reply to message #13495 ] Thu, 10 June 2010 12:16 UTC Go to previous message
Did you unify all the parts of your model correctly? Internal manifold issues or internal volumes could cause this issue. If you're stuck please send the file to service (AT) shapeways.com so they can look at it.
Previous Topic:New collada importer?
Next Topic:Overlapping Geometry Printable?
