Drain hole width
Drain hole width [message #13071] Fri, 21 May 2010 20:20 UTC Go to next message
avatar gharryh  is currently offline gharryh
I want to make a holow object. To let the not used material out how large or small should the opening be.
And what is the best wall thickness?
Re: Drain hole width [message #13073 is a reply to message #13071 ] Fri, 21 May 2010 20:34 UTC Go to previous message
We'd need to know what material you're planning to print your object in to give you a good answer. Also, object size is important.
Previous Topic:Complex assemblies
Next Topic:Problem with STL from Solidworks
