Now i got lost after error message
Now i got lost after error message [message #12611] Sat, 08 May 2010 18:44 UTC Go to next message
avatar gharryh  is currently offline gharryh
I just tryed to upload a design to shapeways.
But i got again a returning message that my object is to big.
Thats strange be-course its about 5x4x3 mm in size.
I created it with AccuTrans from a WRL file,
Any idea whats wrong with the file?
Re: Now i got lost after error message [message #12640 is a reply to message #12611 ] Mon, 10 May 2010 12:48 UTC Go to previous messageGo to next message
VRML is always seen as meters, what size did the email say your file was and what size was it supposed to be?
[Updated on: Mon, 10 May 2010 12:49 UTC]
Re: Now i got lost after error message [message #12661 is a reply to message #12611 ] Mon, 10 May 2010 15:40 UTC Go to previous messageGo to next message
The error reported is:
Your object is too big! The size is 359.80 x 534.90 x 433.30 cm / 141.65 x 210.59 x 170.59 inch (h x w x d). We can only produce objects up to 45.00 x 100.00 x 25.00 cm / 17.72 x 39.37 x 9.84 inch (h x w x d). Please rescale it to make it smaller.
I dint know that it was exported in meter, it should be in mm so 3.598x5.349x4.333mm
I will use AccuTrans to make it smaller.
Re: Now i got lost after error message [message #12662 is a reply to message #12611 ] Mon, 10 May 2010 16:07 UTC Go to previous messageGo to next message
That explains your problem, as you can see it's 100 times larger than you intended. You could try opening the vrml in notepad, go down to where you see scale, and adjust the scale accordingly. It should say 1.000 plus or minus some 0's for x y and z. I think you would change them to .01 to make the file 1/100th scale. Can't recall if it's inverse in vrml, so it may be 100.
Re: Now i got lost after error message [message #12669 is a reply to message #12611 ] Mon, 10 May 2010 17:13 UTC Go to previous messageGo to next message
My .WRL file doesn't contain the word "scale" so what now
Re: Now i got lost after error message [message #12670 is a reply to message #12611 ] Mon, 10 May 2010 17:54 UTC Go to previous messageGo to next message
Well that's a pain Razz, In accutrans, can you scale it down to 1/100th the size? If not, I used your dae file, opened it in blender and experted to wrl. Here's the file. I didn't change the scale though.
  • Attachment: torpedo.wrl
    (Size: 178.47KB, Downloaded 136 time(s))
Re: Now I got lost after error message [message #12672 is a reply to message #12611 ] Mon, 10 May 2010 19:20 UTC Go to previous messageGo to next message
It worked. I could resize using AccuTrans3D
In the Save with option dialogue select Use Units
Then select input units millimetres and the output units Meters.
Shapeways thit accepted my upload
Re: Now i got lost after error message [message #12674 is a reply to message #12611 ] Mon, 10 May 2010 19:32 UTC Go to previous message
Awesome, I just looked through the gallery a second ago and saw it up there, and said to myself, good he got it.
Previous Topic:just thinking aloud - another way to manifoldness
Next Topic:This is how I used sketch-up to successfully print my 3D models.
