My first upload: Alchemy Iron pendant in steel
My first upload: Alchemy Iron pendant in steel [message #12610] Sat, 08 May 2010 18:12 UTC Go to next message
avatar Schaeffer  is currently offline Schaeffer
It was my first upload when I discovered and signed up with shapeways not long ago. I had to wait a bit to have enough to fill the minimum order amount but here it is
I'm so happy, it turned out really nice and finally having an object to compare to my polygon model choices is awesome.
I think I will adjust it slightly just to sharpen up the details in some area's some bevels and such could be a little thicker now that I see it for real. The hidden assassin's creed-ish like alpha symbol is still visible but should be sharper.
Sorry for the bad pictures, I only have an LG Renoir camera phone here at the moment, I will try to get some pictures with a decent camera when I visit my mother later or tomorrow.
http://members.home.nl/davidweb/alchemy_iron_fotos/IMG400.JPG
http://members.home.nl/davidweb/alchemy_iron_fotos/IMG379.JPG
http://members.home.nl/davidweb/alchemy_iron_fotos/IMG386.JPG
It looks a lot grittier on my phone's photo's than in real life, I think that's an effect of it's heavy compression artifacts even on high quality settings.
I don't have much time at the moment but I just had to post some pics Smile although I do have 1 immediate question.
One side of the model is a lot rougher than any other side, I'm assuming this is due to the production process. On the pendant the rough area ended op on its side but still on a visible plane if worn as a pendant, I much rather have had the rough side on it's back which would be hidden by your chest when worn.
Is there any way for a designer to have some control over where this rough side will end up in stainless print?
I will try to get better pics and post some observations for designers soon.
Edit:
An added question, I'm having some difficulty gettng a very detailed spindly design through the manual check for printing after trying several tools and the built-in tools in max to find the problems without any success.
I've downloaded an evaluation copy of Magics RP which is the same tool shapeways uses and it found quite a few potential problems.
Not all of them technical problems with the 3d model but among them should be the ones causing my troubles. But I'm not sure which of the potential problems. Just to see one problem-free file before trying to fix anything I've opened my stl from which this now verified printed pendant was made and its not completely problemfree according to magics but there was no autocheck or manual check failure of the stl and well the printed model is visible in the photographs in this topic.
What I'm wondering now is what are the critical errors one should watch for in magics? Some problems it seem to indicate don't seem to actually present a problem for printing (or e.g. subd smoothing in 3d max.) I just need to figure out which ones they are so I don't waste time on things that aren't actually a problem.
(e.g. It doesn't like one object sticking into another while the actual printer would just make an object out of the intersecting objects according to replies on the forum.)
And does anyone know what the absolute minimum thickness is shapeways checks for on stainless steel?
We all know the 3mm one but the steel page states walls can be below 1mm on object smaller than 5x5x5cm but it doesn't state any real figures.
It would be really neat to know as magics has a wall thickness check but it's only useful if you know all the figures to watch for.
e.g. on the spindly model they indicated 2 legs that would break, out of 8 legs. But all of them are ridiculously thin for a metal print and I cant really find a thickness to test for in magics that gives me a comparable result of only 2 legs being too thin at the .. err ankles..
I think magics might be well worth the high price but how usefull it will be depends for a large part on information from shapeways and how they test.
Maybe shapeways can put some exact information online on how they test? for those of us lucky enough to have magics for example. It would save both the designer and shapeways time I think. (Thinking they likely have some data sheet or some such anyway for the people that check problematic models?)
Edit, here is another picture taking with a somewhat more decent camera.
http://members.home.nl/davidweb/alchemy_iron_fotos/CIMG0874.jpg
EDIT:
It took a moment but I found some time today as I couldn't sleep again anyway haha.
My eye measurements were a bit off in my reply below, but I don't have a hmm the english word is eluding me now "schuifmaat" in dutch. I eyed it with a cheap ruler.
Here are 2 images, I hope they may be off help to my fellow shapers regarding small stainless steel objects.
First my eye estimates with a cheap plastic ruler:
http://members.home.nl/davidweb/alchemy_iron_fotos/alchemy_measurements_printed.jpg
and some actual measurements of the 3d model as it was uploaded at shapeways.
http://members.home.nl/davidweb/alchemy_iron_fotos/alchemy_measurements_3dmodel.jpg
I heightened the face extrusion details a little bit (sub mm change), there is a bar extruded on the bottom a well which was just 0,1/0,2 mm thicker and made for a far sharper look but doesn't look at all much thicker than the top extrusions.
So I adjusted the top to match for future prints.
Hope it is of some use to someone Smile
It's amazing what works below 1 mm I'm really hopeful for the future of the material. I only adjusted the top extrusions 0,1 or 0,2 the effect the 0,1 mm difference has on the bottom is kinda like a sharpen filter on a photo, nothing really changes but it makes a lot of difference.
The pendant shows just a wee bit of warping from the heating process but nothing too bad. In fact with this model I think it works quite well with the warping, gives it sort of character. It's supposed to be an old symbol made in less high tech era's anyway Smile
[Updated on: Wed, 12 May 2010 03:42 UTC]
Re: My first upload: Alchemy Iron pendant in steel [message #12647 is a reply to message #12610 ] Mon, 10 May 2010 13:46 UTC Go to previous messageGo to next message
avatar 4m3D  is currently offline 4m3D
Greta looking pendant!
I am interested in the answer to your first question... the rough side problem.
Great post... thanks for sharing!
Todd
www.4m3d.com
----- TB ----- Todd Bailey www.4m3D.com
Re: My first upload: Alchemy Iron pendant in steel [message #12653 is a reply to message #12610 ] Mon, 10 May 2010 14:21 UTC Go to previous messageGo to next message
Unfortunately at the moment, print orientation is not an option, but may be in the near future.
Re: My first upload: Alchemy Iron pendant in steel [message #12658 is a reply to message #12653 ] Mon, 10 May 2010 15:27 UTC Go to previous messageGo to next message
Thanks for the replies guys! Smile
I will be looking forward to that feature Youknowwho, it's a little bit of a shame the rough side isn't on the bottom which is hidden when worn, it's not too big of a problem on this pendant because it's quite thin. the pendant is about 2mm at it's thickest point in the main shape excluding the loop.
this thickest point is just where the thin detail bar in the centerline is, the rest is more around just 1 mm.
The bars that stick out are more along 1,5 mm thick and a small 2mm wide..
The bars that make the square loop are just 1x1x6mm, the hole itself having a clearance of 4x2mm
the detail extrusion forming the triangle on the arrow head is just I'm estimating 0,1 or 0,2 mm !
I did update the model because I wanted it somewhat clearer/sharper than that after seeing the finished item but still amazing. It makes me confident they haven't quite reached the limit of steel yet
I do get a sense from the model that it really depends on orientation if such an extremely small extrusion works with metal.
I will try and find the time today or tomorrow to make a render showing the measurements from the 3d model, as I'm not having much luck photographing it very well.
Maybe it's me or maybe it's the lack of anything better than phone or quickcam's.
A macro lens would very nice for one thing lol, the option of having raw files to get rid of the coarseness, it really doesn't look as coarse as the images make it look. in the large original pics you can see it's caused by excessive compression artifacts. I'm a bit disappointed I can't get a better picture, it looks like it feels rough but it's really quite smooth :/
I'll try to have that render with the dimensions ready soon hopefully it will help some people out.
[Updated on: Mon, 10 May 2010 15:37 UTC]
Re: My first upload: Alchemy Iron pendant in steel [message #12890 is a reply to message #12610 ] Sat, 15 May 2010 20:16 UTC Go to previous message
Heya,
I finally succeeded in some decent pictures so I thought it was worth the bump Very Happy
http://members.home.nl/davidweb/alchemy_iron_fotos/CIMG1004.jpg
http://members.home.nl/davidweb/alchemy_iron_fotos/CIMG1005.jpg
http://members.home.nl/davidweb/alchemy_iron_fotos/CIMG1007.jpg
http://members.home.nl/davidweb/alchemy_iron_fotos/CIMG1012.jpg
http://members.home.nl/davidweb/alchemy_iron_fotos/CIMG1016.jpg
Previous Topic:Alien Goddess arrived!
Next Topic:UNSCRAMBLED by OSKAR
