Lightwave scaleing
Lightwave scaleing [message #12095] Sun, 25 April 2010 14:03 UTC Go to next message
avatar BCaldwell  is currently offline BCaldwell
Hi all just a quick question as I can not seem to find an answer with search option.
If I make a model in lightwave useing a Lightwave grid scale of say 50mm would the physical model made by shapeways be the same dimensions as the 3D digital model. Or would I have to build the 3D mesh to a different scale in order to aquire a physical model which would be 50mm.
Hope thats not too confuseling, if anyone could point me at a thread where this is already answered or if anyone can answer directly I would appreciate it muchly, thanks Smile
Re: Lightwave scaleing [message #12108 is a reply to message #12095 ] Sun, 25 April 2010 22:40 UTC Go to previous messageGo to next message
avatar coines23  is currently offline coines23
When I do it, I model assuming 1 unit = 1mm, and check the mm option when uploading the STL file. If I have specific dimensions to work to, I'll make a box sized to those dimensions and make sure the final model fits inside that box.
Re: Lightwave scaleing [message #12196 is a reply to message #12095 ] Tue, 27 April 2010 10:32 UTC Go to previous messageGo to next message
Ahh I understand, so when I upload the model in this STL format there is an option to make sure the modelers scale fits to the printers scale IF the correct options are checked by the modeler at upload time. Thank you for that reply thats seems fairly straightforward.
Very Happy
Re: Lightwave scaleing [message #19054 is a reply to message #12196 ] Thu, 14 October 2010 04:25 UTC Go to previous message
avatar Silverbeam  is currently offline Silverbeam
Hey guys! new here and a lightwave user, how do I go about getting a model ready and over to shapeways, is their a plugin to use etc format?
If you could point me in the right direction, that would be great.
Okay, I found under utilities and extra plugins, the option to export as a collada object, but when I do, it is rejected and they say it's too small, I went back and using the measurement tool it was way bigger than the requirements....
Any suggestions?
[Updated on: Fri, 15 October 2010 04:39 UTC]
Support My work at patreon: https://www.patreon.com/silverbeam
Previous Topic:Fixed
Next Topic:adding depth
