Micro-Quadrocopter frame, Eggs on a spring
Micro-Quadrocopter frame, Eggs on a spring [message #10852] Wed, 17 March 2010 14:10 UTC Go to next message
avatar Schorhr  is currently offline Schorhr
My second order arrived.
I printed:
A quadrocopter frame, 15cm, 7 grams
More stable then I thought (2x3, 3x3mm frame, 1,5mm for the smaller parts)
http://www.nottoxic.com/wapcc/3dd/3drahmen.jpg
Coin/Size comparison:
http://www.nottoxic.com/wapcc/3dd/med_P1070938_t.jpg
"Eisprung" (german wordplay, Ei=Egg, Sprung=Jump, actually means "ovulation")
http://www.nottoxic.com/wapcc/ae/aqua/eispr43345.jpg
http://www.nottoxic.com/wapcc/3dd/med_P1070931_t.jpg
Springs really work Smile
Video of the stuff:
Video http://www.nottoxic.com/wapcc/3dd/3ddivx.AVI (6,6MB)
More pics:
http://www.nottoxic.com/wapcc/3dd/med_P1070939_t.jpg http://www.nottoxic.com/wapcc/3dd/med_P1070932_t.jpg http://www.nottoxic.com/wapcc/3dd/med_P1070933_t.jpg http://www.nottoxic.com/wapcc/3dd/med_P1070938_t.jpg http://www.nottoxic.com/wapcc/3dd/med_P1070944_t.jpg
http://www.nottoxic.com/wapcc/3dd/med_P1070949_t.jpg
I also printed a propeller but only the simple one was printable due to thin parts. Maybee more on one of the next orders... And I printed a rotating logo. If I remember correctly I used 0,75mm gaps, and first was sad that it would not turn, but it was just some powder left, and it then turned just fine...
Thank you shapeways for the excelent service, the frame turned out great.
Amazing what even an amateur can do even in a simple program such as Sketchup.
Now I have to wait for motors and electronic parts...
[Updated on: Wed, 17 March 2010 14:12 UTC]
Re: Micro-Quadrocopter frame, Eggs on a spring [message #10853 is a reply to message #10852 ] Wed, 17 March 2010 15:05 UTC Go to previous messageGo to next message
That looks pretty darn good! Very Happy
Moving parts with fine tolerances, springs and what seems to be a very promising microcopter chassis... Nice work!
And you call yourself an amateur.. Very Happy
Re: Micro-Quadrocopter frame, Eggs on a spring [message #10854 is a reply to message #10853 ] Wed, 17 March 2010 15:07 UTC Go to previous messageGo to next message
Thank you! Smile
Well, as I am just learning, and I am using sketchup, I'dd say so... Or have you ever heard of an "MS Paint professional"? Very Happy
Re: Micro-Quadrocopter frame, Eggs on a spring [message #10856 is a reply to message #10852 ] Wed, 17 March 2010 15:19 UTC Go to previous messageGo to next message
I've seen some wicked works of art in timelapse videos of MS Paintbrush so.. yes, I think so.. Very Happy
Re: Micro-Quadrocopter frame, Eggs on a spring [message #10877 is a reply to message #10852 ] Wed, 17 March 2010 22:19 UTC Go to previous messageGo to next message
Wow, thats a really cool heli frame. I wasnt able to watch the video, but did you get it flying yet?
This is a really cool project, its definitely on my list of projects. haha
___________
Check out my shop! http://www.shapeways.com/shops/excitementproductions
Aut Viam Inveniam Aut Faciam
Re: Micro-Quadrocopter frame, Eggs on a spring [message #10880 is a reply to message #10877 ] Wed, 17 March 2010 22:24 UTC Go to previous messageGo to next message
Tommy_2Tall wrote on Wed, 17 March 2010 15:19
Very Happy
rawkstar320 wrote on Wed, 17 March 2010 22:19
Thanks Smile
Unfortunaly not, I am still waiting for the electric components (4 Brushless 5g motors, controllers, and the TTCCv2 quadrocopter control), so the video is just showing the prints Smile
I guess I can still make it a bit lighter and redesign it, now that I can judge the material's properties better.
[Updated on: Wed, 17 March 2010 22:25 UTC]
Re: Micro-Quadrocopter frame, Eggs on a spring [message #11125 is a reply to message #10880 ] Fri, 26 March 2010 13:17 UTC Go to previous message
More images, more stuff!
As I ordered 4 shipments, I recieved the electronics bit by bit (to stay below the ¤22 tax exempt ammount)
Unfortunaly Shapeways allows only 10 images per message (?!)
So I renamed the tags... sorry, links only now.
http://www.nottoxic.com/wapcc/3dd/med_P1070950_t.jpg[/noimg] http://www.nottoxic.com/wapcc/3dd/med_P1070951_t.jpg[/noimg] http://www.nottoxic.com/wapcc/3dd/med_P1070952_t.jpg[/noimg] http://www.nottoxic.com/wapcc/3dd/med_P1070953_t.jpg[/noimg] http://www.nottoxic.com/wapcc/3dd/med_P1070954_t.jpg[/noimg] http://www.nottoxic.com/wapcc/3dd/med_P1070955_t.jpg[/noimg]
ToDo:
-Remove long 1,5mm roll bar: No stability gained, and propeller will protect board when crash occurs as the board lays below them
-Larger controller mounts, datasheet was not correct (verrrry tight fit)
-Maybee save material on the motor mounts, else it's a tight fit, probably works without screws or glue.
Ideas for stability and airflow optimization while waiting for more parts:
http://www.nottoxic.com/wapcc/ae/aqua/ttmfrrev2-345.jpg[/noi mg]
Second shipment...
http://www.nottoxic.com/wapcc/3dd/index3.html
http://www.nottoxic.com/wapcc/3dd/med_P1070956_t.jpg[/noimg]
http://www.nottoxic.com/wapcc/3dd/med_P1070957_t.jpg[/noimg]
Now all motors and controllers arrived
http://wap.cc/3dd/med_IMG_3608_t.jpg[/noimg] http://wap.cc/3dd/med_IMG_3609_t.jpg[/noimg] http://wap.cc/3dd/med_IMG_3610_t.jpg[/noimg] http://wap.cc/3dd/med_IMG_3611_t.jpg[/noimg] http://wap.cc/3dd/med_IMG_3612_t.jpg[/noimg]
TTCC-v2 Copter Control board will arrive soon. Hopefully it flies with this setup, 10g BL might be the way to go instead of 5g, but these are in stock, lighter, cheaper and should still have enough thrust.
Side note: My second order with alumide takes longer then 10 days- is it counted as metal or is it just the deadline that caused people ordering more alumide models then the staff can handle at the moment? Smile
Previous Topic:Aotrs Shipyards construction commences...
Next Topic:Rotabram by OSKAR
