Home » Support » 3D Design » Manifold Error Help
Manifold Error Help [message #10206] Fri, 26 February 2010 00:25 UTC Go to next message
avatar tr3sca  is currently offline tr3sca
I am really new to the 3D printing process, but I am having quite a bit of trouble keeping my models manifold. I have made quite a bit of 3D models for drafting purposes if that helps at all.
Recently though, I made a design I am extremely proud of for my girlfriend's birthday she seems to be in love with it as well... the only problem is... I am really not in the mood to redesign the entire thing again... for the 14th time... (<-actual amount of tries to get it right...)
I am aware that there are a lot of errors for manifold structure, because of this any help is greatly appreciated.
Thank you
~Tr3sca
[Updated on: Fri, 26 February 2010 00:26 UTC]
Re: Manifold Error Help [message #10249 is a reply to message #10206 ] Fri, 26 February 2010 19:49 UTC Go to previous messageGo to next message
I've had a look at your model. I only found a single non-manifold and I've fixed that.
You also had some vertices very close to each other, this can sometimes cause problems with the STL import resulting in a non-manifold. They did not add to the shape of the mesh, so I've merged them.
I haven't done any checks on scale or wall thickness as I have no idea what size you intend this to be.
Regards,
Ian.
Edit ... I've just noticed after posting that my modified STL file is half the size of your original! I've looked at both in MeshLab and they appear to be the same ?
[Updated on: Fri, 26 February 2010 19:51 UTC]
Re: Manifold Error Help [message #10253 is a reply to message #10249 ] Fri, 26 February 2010 21:50 UTC Go to previous messageGo to next message
I don't know what is going on with the size problem... it seems fine in both meshlabs and sketchup on my machine, but I just attempted to upload it to shapeways and it says my dimensioning is too small.
The dimensioning on my machine reads 2" x 1 3/16" x .20 (1/5)". I worked on this thing sideways it looks like, could that have affected my design? And thank you, the manifold error was removed. I noticed that you added diagonals between each polygon, is that something I should take note to? I deeply appreciate your help with this.
Thank you
~Tr3sca
[Updated on: Fri, 26 February 2010 21:51 UTC]
Re: Manifold Error Help [message #10273 is a reply to message #10206 ] Sat, 27 February 2010 17:27 UTC Go to previous messageGo to next message
When you uploaded the design, did you click the 'scale: inches' tick box?
I normally upload STL files in metres, maybe try rescaling.
The diagonals in the polygons are because one of the exporters or importers will have converted all polygons into triangles. Nothing to worry about.
Regards,
Ian.
Re: Manifold Error Help [message #10276 is a reply to message #10273 ] Sat, 27 February 2010 17:55 UTC Go to previous messageGo to next message
Alright, size and everything is alright now. But I have a major problem, it looks like wall thickness came in to play and many pieces of my model were chopped up, the display image in my gallery shows a really messed up image. Any suggestions on how i could fix this?
link> http://www.shapeways.com/detail?model=96262
I am sorry for bothering you. But I can not express how grateful I am for your help.
[Updated on: Sat, 27 February 2010 18:00 UTC]
Re: Manifold Error Help [message #10277 is a reply to message #10276 ] Sat, 27 February 2010 18:27 UTC Go to previous messageGo to next message
We can't see the model yet, it's private?
But probably nothing to worry about, the previews are usually messed up due to a lame smoothing algorithm.
They're working hard on improving that though.Try to download Meshlab, and see how it looks in there.
[Updated on: Sat, 27 February 2010 18:57 UTC]
Re: Manifold Error Help [message #10278 is a reply to message #10277 ] Sat, 27 February 2010 18:39 UTC Go to previous messageGo to next message
It views fine in meshlabs... so I am hoping that it works fine with their printer. I am sorry for any trouble that I am putting people through.
Here is what the model looks like currently from their viewer.
http://img502.imageshack.us/img502/5476/messup.png
I am already very grateful for the services they are offering, when I found this site, it literally made my day when I realized the possibilities for it.
Thank you all once again.
~Tr3sca
Re: Manifold Error Help [message #10279 is a reply to message #10278 ] Sat, 27 February 2010 18:57 UTC Go to previous messageGo to next message
Don't worry, no trouble, and welcome to the club Smile
Re: Manifold Error Help [message #10280 is a reply to message #10279 ] Sat, 27 February 2010 19:01 UTC Go to previous message
Alright... I would like to personally thank both of you. Ian, thank you so very much for helping me clear up my model. Vertox, thank you for clearing up some things for me. Your help is greatly appreciated.
Once again, thank you so very much,
~Tr3sca
Previous Topic:Is there a problem with my upload ?
Next Topic:Yet another topic on manifold errors
