| Can't find Manifold Error [message #10081] Sun, 21 February 2010 02:55 UTC |
I've used MeshLab and Blender, and neither can find the error the Shapeways checker is finding.
Attachment: Atsusit2.STL
(Size: 192.07KB, Downloaded 100 time(s))
| Re: Can't find Manifold Error [message #10082 is a reply to message #10081 ] Sun, 21 February 2010 04:22 UTC |
When I tried the "Remove Non-Manifold Faces" function in Meshlab, it found and removed 88 faces, after which the model was apparently manifold and free of holes. (I also had it remove duplicate vertices when opening the file.) I'm attaching the result.
Blender thought it was manifold after the removal of duplicate vertices. Blender typically removes "duplicate" vertices that Meshlab does not think are duplicates, so this may be the reason for the difference. (Although my past experience has been that Shapeways is more likely to agree with Blender than Meshlab on this.)
| Re: Can't find Manifold Error [message #10088 is a reply to message #10081 ] Sun, 21 February 2010 12:45 UTC |
I attached to model in a way that uploads fine to Shapeways.
Bye,
Alex
| Re: Can't find Manifold Error [message #10095 is a reply to message #10088 ] Sun, 21 February 2010 16:37 UTC |
Thanks! Strange that Meshlab found it for you, it always reported zero for me.
| Re: Can't find Manifold Error [message #10395 is a reply to message #10095 ] Wed, 03 March 2010 15:43 UTC |
Did you try both "Non-manifold faces" and "Non-manifold vertices?" I've found that the removal of one will introduce the other, such that the other filter needs to be run again. I've also found that re-running the filter can crash the system. And that after saving, I can get more errors if I re-run either filter yet again. And sometimes it will find the same error that it claimed it had just fixed
Basically, my experience with MeshLab has been that it has some interesting features, but that it's buggy, unreliable, inconsistent and prone to crashes.
