| hypernurbs [message #10031] Thu, 18 February 2010 21:58 UTC |
Does having fewer polygons lower cost...if so, does using a hypernurbs object to smooth have any bearing on this...
Thanks G
| Re: hypernurbs [message #10033 is a reply to message #10031 ] Thu, 18 February 2010 22:03 UTC |
No, cost is based on volume (see the Materials page and note that all prices are per-cubic-cm, sometimes plus a fixed startup cost).
SW doesn't accept anything over 500,000 triangles, and you can't make a 2-manifold (printable) object with fewer than four triangles, so those are the only polygon-related constraints you need to worry about.
