inverted normals in rhino
Discussion in 'Design and Modeling' started by 9446_deleted, Apr 29, 2009.
  1. 9446_deleted
    9446_deleted Member
    im having trouble in rhino, shapeways is saying my models normals are inverted and as far as i can see it's not? can any one help?
  2. RalphVdB
    RalphVdB Well-Known Member CS Team
    Hi scott-tweeddale,
    I took a look at your model. It had a lot of inverted normals. I took the liberty to fix it for you :laughing:
    Just upload it , order it and it's yours :nod:
    Ralph
  3. 9446_deleted
    9446_deleted Member
    Thanks for fixing. Out of interest how did you fix it?
    Appreciate the help
    Scott
  4. RalphVdB
    Hi Scot,
    I used the fixed wizard and removed all the inverted normals, and some bad shells. That's all :cool:
    Ralph
  5. 9446_deleted
    9446_deleted Member
    is that something in rhino at all or something you use at shapeways?
  6. RalphVdB
    No, we, at Shapeways, use Magics
  7. ArMOO
    ArMOO Member
    Hi Ralph,
    I saw you fixed some files with magics.
    Could you also fixe the dragonnecklace?
    How did you fix the tank without destroying it?
    Could you show the method with some screenprints?
    Greetings AO
  8. 9446_deleted
    9446_deleted Member
    Hi
    I'm still having problems working out normals in Rhino and i was wondering if it was possible for you to have a look at these files for me as well?
    Any further help would be much appreciated
    Scott
  9. 9446_deleted
    9446_deleted Member
    these two aswell
  10. 9446_deleted
    9446_deleted Member
  11. Gijs
    Gijs Member
    Hi Scott,
    not sure, but you're probably using the wrong mesh settings out of rhino. I just downloaded your lens2 and lens3 models,
    They both contain open meshes which is not good for 3D printing
    If you send the rhino model, I can see if it is a problem with the mesh settings or with the model itself, it could well be a combination of both. I guess that's the case, because lens2 had interfering mesh faces as well.
    Gijs
  12. 9446_deleted
    9446_deleted Member
    Hi
    Thanks to everyone for their help, i've managed to sort it out and order it all, i had to re make it froms scratch
    Thanks to everyone for help
  13. RalphVdB
    Hi Scott,
    I am glad you succeeded to upload your models!
    Hi AO,
    Just send the model to service@shapeways.com and we will take a look at it :cool:
    There is an Shrinkwrap option in Magics, which takes care of this.
    I will make time for this next week. Maybe i can make a simple tutorial and put in on the support section
    Ralph
  14. ArMOO
    ArMOO Member
    Ralph,
    The dragonnecklace is not mine but from murderslastcrow If I remember well.
    I'm looking forward to your tutorial.
    Cheers AO
