Shapeways materials for antenna substrate
Discussion in 'General Discussion' started by tempusr148368_3f283a8417, Feb 15, 2012.
  1. Hello all,
    I want to create a printed antenna on a suitable shapeway substrate. Does anyone have an idea if it is possible to create a radiating antenna on the materials provided by shapeway?
    Thanks.
    Mayur
  2. stop4stuff
    stop4stuff Well-Known Member
    Hi Mayur,
    Welcome to Shapeways! :)
    I haven't a clue about the workings of an antenna, so I'm not sure if the materials would be able to act as an antenna, but if it is the base shape you're needing for doing post production work on to make a functioning antenna then, yes, just about anything you can imagine can be printed.
  3. stonysmith
    An example: the technical name for WSF is Nylon 12.
    If you look that up on the web, you will find:
    http://www.goodfellow.com/A/Polyamide-Nylon-12.html
    But, this doesn't give you the dielectric constant at different frequency settings. It may be available somewhere.. you'd just have to research it deeper.
  4. I have characterized all of the materials provided from shapeways and they are all very lossy with a loss tangent of at least 0.05 at 1 GHz. The white, strong, and flexible is particularly bad because of its extreme porosity. Depending on humidity its dielectric loss tangent varies from at a minimum (after desiccating the sample for 72 hours) of 0.07 up to 0.2 after sitting out in an ambient relative humidity of 35% for 24 hours.
    If you do move forward with your idea don't forget that most cyanoacrylate based adhesives are stupidly lossy in the RF-microwave bands. Make sure you choose an rf grade adhesive.
  5. Hello all,
    Thanks for sharing the valuable information. I will be testing a micorstrip antenna on WSF antenna soon. Will share my results!
    @Tamert What do you mean by RF grade adhesive?
