Happy that you like our Earth
There are two issues reguarding what you asked:
- first the size: if the thickness is maintained to 3mm (which can be done until a certain diameter), the price will be multiplied by 4 each time you double the radius.
- second, I need the data in a correct form: the altitude in level of grey and the color map (including a representation of what is under water). Have a look
here. The format for the altitude is quite strange (with negative values in the image): not sure I can use that... And still I have no other color than the blue of the ocean to represent what is under water...
