Hi guys, Rob Mack here, I've been using the Shapeways service for many things, one of which is my latest move towards the designer toy industry.
I have worked with the parts printed by Shapeways with varying degrees of success and think it a good idea to post my findings here... Hopefully some of you will be able to avoid some of the mistakes I made.
Firstly, I just want to say that
Industrial Steel Wool has changed the way I work here. It comes in varying grades and is perfect for sanding in fiddly corners and on broad surfaces. I still use wet and dry sandpaper but steel wool always play a part in the finishing process.
OK... Let's get down to business here...
WSF: I've found this material to be exceptionally sturdy and the grain of this material, particularly at the bottom curved surfaces can be quite persistent... I usually attack these areas where the grain is most evident with a 240 grade wet and dry until they appear a little smoother.
I then coat with spray paint. Any spray paint will do the job but of course, you get what you pay for. I use
Mr Surfacer 500 Spray Primer here when only the best will do. This paint is really thick and grainy itself and great at filling in the grooves of the print. I usually give (over 24hrs) 3 coats of this paint to my model and then leave it for 24hrs.
That's when the steel wool comes into it's own. The surfacer primer is like matte plastic when it sets and allows the steel wool to sand away the groove impressions in the layers of paint to leave a fairly smooth surface. basically what I aim for at this point is to have the grooves or grain of the print filled with primer and the primer sanded back almost down to the bare print. I may repeat this process if necessary, particularly on very small models.
From there, once happy with the overall smoothness I go to
Tamiya fine spray surface primer. This stuff is also expensive but awesome!.. I've been working with paints for over 20 yrs and have great respect for a good quality paint. This paint is just what it says, a fine finishing primer. it goes on silky and sands to perfection. By now I am down to my finest grade of wool and just coat, return a couple of hours later, sand it back, coat again, sand etc until it's perfect.. Sometimes, depending on the level of detail I'm after, this stage can take up to a week.
Now I tout the good paint because of my experiences with hardware store paints... I purchased many models as protos for moulding and the process of making the mould creates a great deal of heat (here comes the tears) Cheap paint likes to do all sorts of things under heated conditions and I've had my beautiful weeks work of sanding come off my protos 'in mould' basically rendering my proto, and the mould, useless... I also have had some issues with cheap paint becoming sticky when sanding and 'balling up' basically ruining the surface I'm trying to create...
Detail Material: process here is same as for WSF but the softness of this material lends itself better to initial sanding before painting. It really takes to wet and dry sandpaper as well as steel wool so it's far better a choice for prototyping for moulding than WSF. The only disclaimer I'll offer with that statement is that detail material doesn't absorb paint as much as WSF and if using cheap paint you may experience some peeling under heat. No problems when using the other 2 more expensive paints above tho.
Will post some fotos soon
Hope that helps some of you who are interested in taking your prints to the next level
Cheers
Rob
