An update.
I've had the opportunity to have a play with removing the wax residue and straightening out the sidewalls. The process went like this;
1. - Grab wifey's nail varnish remover (NVR) and a stiff artist's brush.
2. - Work the NVR over the wax residue with the brush and drop the part into a glass containing cold water (50ml/~2oz) and washing-up liquid.
3. - When all the parts were in the glass, I put the glass into the microwave oven and 'cooked' it for 60 seconds on the 300w setting.
4. - Left to stand for a few minutes, then lifted out the parts, some onto kitchen towel, the sidewalls straight onto the kitchen worktop - the parts were quite warm and flexible at this point - the water coating the sidewalls sucked the parts onto the worktop (surface tension) and as they cooled they remained fairly straight.
Images;
Less warped - here you can see the sidewalls have just a slight bow, glue & a bit of pressure will get things lined up & true.
Large image here
The phone - check out the large image, the dial is visable and the finger holes are just showing.
Large image here
Yet more detail - the door handle, and 'TELEPHONE' across the top.
Large image here
My next steps prior to painting are to thoroughly clean the model - how, I'm not quite sure. I'm not in favour of using any acetone based product due to the way it 'frosts' the plastic as can be seen above... to me, frosting means the plastic has been chemically altered and is now more brittle - even if this is just the surface, there's only so much thickness to play with (the sides are minimum 0.3mm wall thickness)
After reading about other people's methods, I'm headed towards using a glass fiber brush. I have some glass fiber tape with really fine strands that may work out ok making my own dremel type accessory, and I'm all for experimenting
On with the
fun FUD!
[edit]The kiosk has had a chance to sit, made up (dry, no glue), for a while and all the sides are now straight
