Hello, I've made a model that has tiny parts I'd like to move. I believe I've left at least .5mm for all gaps and the minimum thickness of any object is 2mm. Does someone mind just double checking to make sure everything won't fuse together when it comes time to print it? I'm not ready to spend this much and find out it doesn't work. Let me know what format works best for you (currently a Maya binary file). Thank you for your help.
Oops, key part missing. Here's what it on shapeway's site: https://www.shapeways.com/model/10328/vault_container.html
Hi pzich check out this link: http://www.click-to-fit.de/easyfit.php?&lang=en Easy fit is free software. With this software you can easily check your thickness. Just use the measure distances tool! Cheers, Ralph
