Hello all.
You may or may not have seen my previous N scale (2mm/ft) rides, but I have more!
As before, these are in WSF.
Reverse Bungee.
Due to the size of the piece, the material is very delicate, and the arms could not be produced in place, so they came detached, and I'll glue them on at a later date.
The bottom frame measures 130mm long, and the arms are each 170mm.
The Cage is 13mm wide & the Cage bars are 0.8mm in thickness, which I know is not in scale, but I wanted half of the cage to be printed, whereas the other two bars, I may make out of rod.
Overview:
And the Cage:
Freak Out Style Ride.
After many attempts of trying to get this model printable, I finally have it in my hands, after spending countless hours head scratching!
It measures 95mm Long, 58mm Deep & 78mm High.
The seats on the cars are a perfect size, and I also have 4 spares.
I couldn't really find much helpful information, regarding dimensions, but did the best I could.
At the beginning of modelling, there were a few issues with the Model, that had to be sorted before it could be Printable, and there has been several different size parts within the Model.
When I made the Cars, I came to add them to the Arms, and found the main Arm was too low, so had to raise it up, which in turn, made the main shaft shorter, which to my eye, looked too short, so I also made that higher, which meant the Main arms from the base, had to be completely redone. So, it's been a rough long 'Ride' to get this far, so I'm happy with the result.
Overview:
Log Flume Boats.
They were made to fit our Log Flume Track, that I made, and do fit a 2mm Scale person in.
It was stupidly hard to try and focus with something of this scale!
Thanks for looking, more to come soon, Including a Top Spin, which is based on the original travelling version, & A "Glass Maze", which Will be lit...
I'll keep ya'll posted,
Tom.
