I never did get a command line script to work for the bulk upload but I did go back to the stock example and made it work. Here it is. Please note the comments...particularly the ones about this being a work in progress, not meant to be an example of good techniques, etc, etc, etc. Hopefully someone will find this to be a useful reference as I had a hard time finding a good example to draw on!
Code:
# ** BulkUploader.py - Bulk Upload Script for Shapeways.Com
# ** You will need to visit the following page to get started as you need some
# ** Oauth stuff to get started. There is a link on the first page that will
# ** take you to where you need to be to register an application:
# ** https://developers.shapeways.com/getting-started?li=devhome_main
# ** Once that is done update the below path statement to point to the directory
# ** where your models are stored...and where this program can find your
# ** Index.csv file that contains an inventory of your models with some
# ** added details for the listings to be created. The model title will be
# ** the model file name. The index file has that name as the first column,
# ** a numeric column that is currently not used but envisioned for markup,
# ** a model specific description that is appended to a stock description, and
# ** then a list of tags.
# ** This is far from a finished piece of work...nor is it eloquent coding,
# ** nor in fact does anything about the user interface make one smile! What
# ** it does do, however, is provide a working example of an upload!
# ** Run this script in a terminal window. Go to your browser and enter
# ** localhost:3000/login. You should be asked by Shapeways whether it is
# ** ok for your app to access your account. Press the button and your upload
# ** should be processed.
import json
import base64
import os
import csv
from shapeways.client import Client
defaultPath = "/media/psf/Home/Desktop/models"
client = Client(
consumer_key="YOUR GENERATED KEY HERE",
consumer_secret="YOUR GENERATED SECRET HERE",
callback_url="http://localhost:3000/callback")
def application(environ, start_response):
url = environ["PATH_INFO"]
if url.startswith("/favicon.ico"):
start_response("204 No Content", [])
return [""]
elif url.startswith("/login"):
url = client.connect()
start_response("302 Found", [
("Location", str(url)),
return [""]
elif url.startswith("/callback"):
client.verify_url(environ["QUERY_STRING"])
("Location", "http://localhost:3000/"),
print "Going to uploadFiles"
uF = str(uploadFiles())
print "Back from uploadFiles"
return (uF + " files Uploaded")
else:
start_response("200 Ok", [
("Content-Type", "application/json"),
return ""
# Drives the uploading of all files ending in .stl found on the default path
# and in all of its subdirectories
def uploadFiles():
fCount= 0
for root, dirs, files in os.walk(defaultPath):
print str(files)
for file in files:
if file.endswith(".stl"):
print "Uploading " + file
uploadFile(root, file)
fCount += 1
return(fCount)
# Uploads an individual file found above
def uploadFile(root, file):
# Find the model in our inventory index file
model = findModel(file)
if model == "":
print "NO match"
return
f = open(os.path.join(root, file), "r")
# Create the payload expected by the API
payload = {
"file": base64.b64encode(f.read()),
"fileName": file,
"hasRightsToModel": 1,
"uploadScale": 0.001,
"acceptTermsAndConditions": 1,
"title": file,
"description": "This is a test: " + model["description"],
"tags": model["tags"]
f.close()
# Add the model
t=client.add_model(payload)
# Load our inventory of model files from the csb index file. Model file name
# is the key, then download proce (who knew this was not an option! Followed
# by a field for additional description, and then a list of tags
def loadInventory():
ifile = open('Index.csv', "rb")
reader = csv.reader(ifile)
for row in reader:
tags = []
for i in range(3, len(row)):
tags.append(row[i])
model = {"name" : row[0], "price" : row[1], "description":row[2], "tags": tags}
temp = row[0].upper()
models.update({temp: model})
ifile.close()
# Find the model file returning "" if not found
def findModel(model):
try:
return(models[model.upper()])
except:
return("")
# Primary execution
if __name__ == "__main__":
from wsgiref.simple_server import make_server
models = {}
loadInventory()
try:
httpd = make_server("", 3000, application)
print "Tracking Server Listening on Port 3000"
httpd.serve_forever()
except KeyboardInterrupt:
print "Exiting"
Code:
Drum.stl,1,"Something extra","Germany","Heavy"
Drum2.stl,1,"","Germany", "Medium"
Missing.stl,2,"","USA","Medium"
Drum4.stl,1,"One more extra thing","France"
