Create a shop
Discussion in 'Shapeways Shops' started by 35857_deleted, Feb 27, 2010.
  1. 35857_deleted
    35857_deleted Member
    HI,
    I have upload one of my designs and I still can't create a shop. Nothing happens when I hit the button. Is that normal ? Or is there a special requisite to be an owner ? I didn't tick the business user...
  2. virtox
    virtox Active Member Moderator
    Sorry, I don't know, the only thing I can think of, is to highlight the obvious points I know :
    Name, billing address and paypal account info should be filled in.
    And not 100% sure, but I don't think business user is a requirement.
    But that nothing happens when you press the button is probably not normal..
    No feedback ? No page refresh ? Do you use any refresh blockers ?
    I guess shapeways will respond around next monday.
    Best to also post your OS and browser versions just in case.
  3. 35857_deleted
    MY shipping adress and paypal infos are in...I am using IE8 and Firefox 3, on Win7 64 bits. No, I got no message of any kinds...
    I will try updating my java version maybe...
    Update: My version wasn't updated anymore, but it didn't changed anything. Gonna wait then...
  4. 3401_deleted
    3401_deleted Well-Known Member
    Have you filled in your phone number ? I had this problem, and the phone number was required although it was not marked...
    This bug was transmitted to Shapeways, I think it is fixed now.
  5. 35857_deleted
    Yes it is filled. Still not working...
  6. pete
    pete Shapeways Employee CEO
    phone nr is not required.
    When you hit create shop under 3 it should change to form entries where you can specify the Shopname and URL and a tickbox.
    Is Javascript enabled?
    Pete
  7. 35857_deleted
    In firefox, yes, the java option is enable.
    what I see when I hover the button:
    javascript:void(UDesign.Shop.hideCreateButton())
    I see that my shipping address has been recorded in a light grey box. Should it also happen in the billing address area, because it's not the case...Often the forms have a lot of trouble with the postal code...
  8. 35857_deleted
    Any news on the problem I am having ?
  9. 33749_deleted
    33749_deleted Member
    We are looking into it, but it seems to be a rather peculiar case.
  10. 35857_deleted
    Ok thanks. I am always a particular case :D
    Let me know when you found or fix something.
  11. 36116_deleted
    36116_deleted Member
    I'm having the exact same problem....nothing happens when I push the button.
  12. 35857_deleted
    I think your update did something, because I was able to create my shop today. :D
    Just to let you know.
  13. 33749_deleted
    Yes, we had a update of the site yesterday.
    I think the cause of the problem was because of an update we had earlier that introduced a new address standard. This actually changed a bit how we stored user data.
    What I think happened is that the checks and validations we do when people open a shop was still trying to access the old data, which incidentally for older users is still there. But for newer users isn't. We slipped up in Q&A on catching that. But it got fixed in yesterdays update.
    Well anyhow, I'm glad you've now been able to open up shop. I will look forward to seeing your models :) (especially because of the new thumbnail render system, it makes everything look prettier)
  14. 35857_deleted
    Yes. Kudos on your new render engine. Very nice work.
  15. 44201_deleted
    44201_deleted Member
    I am having the same problem (July 5th)- I press the button, nothing happens. :(
    Help?
  16. robert
    robert Member
    I just unlocked your shop. So you did managed to create your shop. Maybe you missed some of the communication?
    There is a small manual review process with regard to opening a shop.
    I will look into the shop creation process to see if all is well.
    Cheers!
    Robert
  17. 50684_deleted
    50684_deleted Member
    I am having the same problem (sep 17th)- I press the button, nothing happens. Sad
    Help? :eek:
      File size:
      145.6 KB
      340
  18. 47360_deleted
    47360_deleted Member
    I am having the same problem (July 5th)- I press the button, nothing happens. Sad
    Help? :)
