My First print arrived !!
Discussion in 'My Shapeways Order Arrived' started by 337474_deleted, Apr 18, 2013.
  1. This is my first time using Shapeways service.
    The print is finished nicely :laughing:
    It come with three prices. Need some work to assemble it with proxy glue.
    Enjoy.
  2. 6339_deleted
    6339_deleted Member
    Very nice work!
  3. philnolan3d
    philnolan3d Well-Known Member
    That's great! Good idea making it in pieces too.
  4. lensman
    lensman Well-Known Member
    Excellent job. Did you make it in separate pieces for easy customization or because of printing size?
  5. I make it seperate to reduce the weight of her head :D
    Her neck is weak. I join her small braids to her right shoulder make two supporting points of the whole head.
    Also, it reduce volume hence reduce cost :laughing:
  6. lensman
    Very good idea. Is the volume reduced because you could hollow it out when model was separated, whereas you couldn't when it was one piece?
  7. You are Right :p
    Separate the a large piece make it easier to hollow. Especially shape that not easy to make escape holes.
  8. karims
    karims Member
    How did you get the colors done?
    Does 3D print, if you give colored model, they will color it accordingly? I am new to all this, so I am trying to know.
  9. lensman
  10. Yes, it is fullcolor sandstone. You can apply a texture to the model and paint it as you want :p
    You can shade you model on the texture, so the model would have more depth and better look.
