I'd like to print a few creature figures from my film. I figured I would use the "white strong & flexible" plastic material (or would you suggest something else?), about 10-15cm tall... but this is my first time so there a few points I'm not sure about:
-will these tiny insecty legs be able to support them? They will be about 3mm thick at some parts (I did some measurements)
-will the tiny claws deform a bit (they are about 1-2mm thick, but at the very ends it's bellow one mm)
-as I add some base blocks for them to stand on, can I just leave them as separate shell when exporting as STL, or do I need to make a nice and clean single mesh in Zbrush?
-if I decide to make those larger body masses hollow to reduce costs, where do I place the cleaning holes?
Thank you,
looking forward to your answer.
Here are some measurements for a 10cm figure:
