Q: Will they be able to pour silver during casting with all this detail talking up space or should I leave some blank space on the bottom? I didnt do a whole lot on the bottom just in case I need to change it.
Good question! The silver printing is a two part process, first we 3D print in wax, then cast into silver using the traditional lost wax casting method.
Great wiki here:
http://en.wikipedia.org/wiki/Lost-wax_casting
Since this involves "spruing" the models, which is essentially attaching a branch of wax that becomes the funnel for molten silver to pour through, it IS a good idea to have one spot (usually the bottom) that is free from detail so the sprue can be attached there (and then removed, without removing your detail).
It *is* possible to attach a sprue to the inside of a ring, but this is more complex, and more often results in a bad cast.
It's great that you are thinking ahead to the process when you are designing, so yes, do leave a small area of no detail on the bottom of the ring.
Another benefit of doing this is since this part is inside your hand, it will be more comfortable to wear.
