Very good! Thanks for the link. I was having problems finding it, and I knew I had seen it.
So, to have a disc that is 27mm in diameter (with a cut-out design in the center), the thinnest it can be is 3mm, correct?
When does the "minimum detail" of .1mm come into play, only when sitting on top of a part that's already 3mm?
Anyway to use sprues or other somewhat removable pieces to achieve the same effect and keep the core thickness of the disc to 0.5mm - 1.0mm?
Also, I did upload a model that was 3mm thick, but Stainless Steel was not an option. Does it have to be 3.1mm to pass "the test"?
- Sean
